Question about Nikon COOLPIX S51 Digital Camera
Transfer pictures from my Nikon, Coolpix S51
When I try to transfer pictures from camer to computer I get the message that the camera is busy or not conntected. I made sure the battery was fully charged; disconneted the usb from computer and waited before reconnecting again, still showing busy or not connected. I have transferred pictures with no problem in the past.
  • 120 Answers
Hi
Restart the system and then try it...
Thank you
Posted on Feb 10, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Try to plug into a different USB port. If that does not help then go to Control panel->systems-> hardware tab-> device manager->and now try to see if your Camera appears under the options listed (would be under Scanners and Camera, Click on every + sign to see)
Do rate the solution.
Thanks
Rylee
My nikon s51 will not turn on when I plug the transfer cable into the camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Feb 08, 2013 | Nikon COOLPIX S51 Digital Camera
For some reason when I connect my Nikon Coolpix S51 to my Macbook the device is not recognized. I have connected it, using the same cord, to my hp desktop and it connects and is found immediately. Any...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or iPhoto or any other photo cataloging program.
Aug 15, 2010 | Nikon COOLPIX S51 Digital Camera
COOLPIX S51 Digital Camera: I turn the camera on then connect it to my Mac via...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
May 16, 2010 | Nikon COOLPIX S51 Digital Camera
My nikon coolpix s51 show message memory card is
For the message that show's on your camera here's is what your need to do. 1. Remove the memory card and check for the physical lock toggle.
2. Toggle the lock on and off.
3. Try blowing on the memory card and the memory card port so it will be cleaned somehow. here is the picture of the lock toggle of the SD memory card 919a7e0.png
Apr 13, 2010 | Nikon COOLPIX S51 Digital Camera
I have a Nikon Coolpix s51 but my screen is cracked. I am trying to transfer the photos from my memory card and camera to my computer, but i am having trouble figuring out how to do that???
At this point, I would remove the card from the camera. If you don't already have a card reader, invest in one. Connect the card reader to the computer, then plug the card into the reader. You can use Nikon Transfer ( http://support.nikontech.com/app/answers/detail/a_id/61 ) or the operating system's drag&drop to transfer the pictures to your computer.
If you have pictures stored in the camera's internal memory and the screen is at least partially legible, you can try to select "Copy" from the Setup menu to transfer pictures from the internal memory to the memory card before you follow the suggestions in the first paragraph.
Feb 03, 2010 | Nikon COOLPIX S51 Digital Camera
Cord and CD for Nikon S51 camera
take the camera into a computers store they should have a cord if not they can order. or try ebay .. you shoukdnt need the cd for the pictures to load on the pc. i have a nikon and have never used the cd . my pc just picks up the camera when its hooked up..
Mar 24, 2009 | Nikon COOLPIX S51 Digital Camera
CANT TRANSFERRENG PICTURES COMPUTER TO CAMERA
The Nikon has software that allows you to transfer/copy photos to the computer.
There is an alternate method of transferring photos.
Get a USB memory card reader, remove the memory card from the camera and insert it into the USB card reader and then plug it into the computer's USB port. Thes computer will see the memory card as an external memory device, You can then copy the photos to your computer.
Jan 17, 2009 | Nikon Coolpix S51c Digital Camera
Nikon S51 transfering pics to computer?
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program, such as Picasa.
Organize edit and share your photos
Jan 28, 2008 | Nikon Coolpix S51c Digital Camera
Nikon Coolpix S51 - unable to install software on Window ME
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Dec 06, 2007 | Nikon Coolpix S51c Digital Camera
Nikon COOLPIX S51 Digital Camera Logo
177 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
