Question about Maytag Washing Machines
Neptune drain pump propeller
My Neptune 8700 front load washer doesn't drain correctly so I took the pump apart, only to discover 2 of the 3 plastic blades had broken off. New drain pump is over $100 while all I really need is the shaft with 3 blades ($10?). Anyone have any ideas per obtaining this part.
With complements, RT
  • ternosky Feb 10, 2009
    Been there. The will sell a hex nut but not any component of the $150 pump. Thanks, RT
  • 360 Answers
With your model #, go to this site for a pump/parts -->click here<--
clarkco
Posted on Feb 10, 2009
Amana front load washer how to clean water pump
remove the hoses and and remove the pump then use coat hanger to try to clean inside pump and try to turn propeller by hand depending on ur model some pumps cant be taken apart depending on either direct or belt driven ones
Aug 09, 2014 | Amana NFW7200TW 27-in. Washer Front...
Washer does not drain
The pump may be clogged. Disconnecting the drain hose will not solve the problem, you have to check inside the pump
Oct 28, 2012 | Maytag Neptune MAH5500B Front Load Washer
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water will not drain on neptune MAH3000AWW washer tried different cycles. It started working for a while after we took back off and took things apart but now it won't drain at all.
There are many things could make a dishwasher not drain, here's a list of the most common reasons.
  • a clog or air gap in the drain line, often the problem is where the drain line attaches to the household drain line, if you remove this line you can clear any debris from the hose or hose connection.
  • a defective pump, your dishwasher pump ejects the water.
  • many dishwashers use a drain valve or solenoid, the solenoid can sometimes become stuck or defective solenoid.
  • a defective motor, if the motor is'nt turinig or working the dishwasher won't drain.
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer does not drain the water, it is a front load washer. I have checked the pump already.
Noises - the original pump was a 40 watt pump, it often made a "howling" like noise. Replace the pump...the newer 80 watt pump has been more reliable.
Not draining - Front load washers are very bad for getting "junk" into the pumps...buttons, nails, zippers, bra wires....remove power and the front panel to access the drain pump assembly.
Remove power first! The pump is very easy to remove, ( unlocks from the base ) take the pump apart and check for foreign objects inside the pump assy. The power wires pull off and matters not which way they go back on. Also check the hoses to and from the drain pump for any  foreign objects. The pump is usually at the back right side ( looking at the washer from the front ).
for the diagrams click the link
http://www.applianceaid.com/neptune6.html
Mar 02, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Washer Not Spinning All Of The Water Out
It's not supposed to. They all keep water in the drum after wash is finished. Was told by Maytag its to keep the balance of the spin cycle, like balancing a tire with lead weights.
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
HOW DO I GET TO THE PUMP TO UNCLOG IT
siphon to drain the water then flip the washer sideway and locate the motor cuopling or broken belt and change this to a new one
Jan 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
Open Questions:
Maytag Centennial: Not starting, maybe lid lock issue? How to install new magnetic lid latch? then is replacing lid lock next or could it be something entirely different? Help, please, and THANK YOU! I have a Maytag Centennial washer MVWC450XW3 that quit working last week. In hindsight, I could see that there had been a history of "stuff" going on with the washer, all around the lid lock;i.e. - last time it worked I had to select a couple of different cycles before it finally started. SO Far, I have tried to get the diagnostic codes but failed a bit at that. I THINK that I was getting an F5E1 error. I was however at least able to access the diagnostic menu, and notice TWO things: No matter what, the Lid Locked LED never comes on, ever. Next thing I notice is when I do a short cycle diagnostically, it never agitates or spins. It fills various temp water, does not agitate, then it seems to suck the water back out. IN the end, I ordered just the magnetic part of the lid lock (the part that is actually on the lid) because I could see mine was rusted all the way away, but am not too sure how to put it on. Therefore I just put it in the slot where it would go if I had installed it. Incidentally II asked my ma if she had noticed anything going on with the washer and she said No at first but then with prompting (she's 81) allowed that she had indeed noticed something wrong with the lid shutting so she had cleaned out that "little hole"{ very well and oiled it to make sure it was working. So again my two main questions are: How to install the lid latch, do I need to take out all of the screws around the glass? and Should I next move on to buying a lid lock part or could it be something entirely different?
Mar 21, 2017 | Maytag Washing Machines
Washing Machines Logo
99 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
