Question about Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00
Noisy water heater blower
I recently noticed my 3.5 yr old water heater blower is making a vibrating noise. Never noticed it before. Could there be a problem?
  • 332 Answers
Yes the bearing could be gong bad, the screws could be comming loose which could make it where out the motor faster, it should be attended to
Posted on Jun 06, 2009
2 Suggested Answers
mcgyver468
  • 710 Answers
SOURCE: noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Posted on Apr 24, 2009
Noise blower motor
leave unplugged... water will stay hot.
Plug in for 1 hour to make tank of hot water
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Jan 18, 2014 | Water Heaters
Sounds like a truck
If the heater is more then a few years old the heat exchanger is probably corroded. Air flow from the blower motor can't squeeze thru the exchanger fins and causes loud vibrations. It can sometimes be cleaned but usually requires replacement of the heat exchanger. If you are not familiar you should definitely have a professional sevice the unit. Continued use in its current state can cause many other issues. Be prepared because the heat exchanger is the most expensive part of the heater and the most difficult to replace
Jan 10, 2014 | Water Heaters
Loud vibration
1) What brand and type water heater? Gas or electric? Tank or tankless? Or boiler? Solar assisted? Indirect? Wood-burning? Oil-fired? etc?
2) How old is heater? Is this a new installation? Or installation that worked before and vibration is something new.
3) Or are you talking about a washing machine instead of water heater? Or hair dryer? Or GMC truck?
4) Add a comment and give more exact information from label located on side of unit, for possible assistance.
Feb 18, 2013 | Water Heaters
Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
Jul 03, 2010 | Rheem Direct Vent Natural Gas Tankless...
Bradford White hot water heater - burner lights only 30 seconds
The slightly warm water makes me think of a thermostat problem. The fact that the heater is 10 years old I wonder how hard your water is. Calcium build up kills water heaters. But the yellow flame you mention could be the results of dirty orfices. May want to have a Pro look at that.
May 03, 2010 | Water Heaters
There really is no way to do this. If you put a cap you will restrict the air flow which will cause you to have problems with the water heater, same thing if you where to put screen on it. You can try enlarging the pipe to a 3 inch and see if that works. But 15 years in the trade nothing has been made to reduce the noise
Jun 01, 2009 | Fasco Bradford White Hot Water Heater...
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Dec 31, 2008 | Rheem 81VP6S/430126 Water Heater
Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00 Logo
919 people viewed this question
Top Fasco Water Heaters Experts
Charles T Nevin
Charles T Nevin
Gil Shultz
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
