Question about Xerox Document Centre 265ST Printer
Document center 470 ST says network controller unavailable.
Turned of the machine at least a dozen times but fault remains. What can I do?
    President:
  • 2,072 Answers
Most likely the network hard drive has failed. The hard drive us located inside the network controller box .
Posted on Feb 11, 2009
The phone keeps saying everything is unavailable,and emergency calls only.Have turned it on & off and taken battery out for a while but they have not worked.Have you any info on what to do. ...
Check your handset will accept your sim cade. It sound like you handset is lock to a diffrent network and need to be unlock you can get a code for the network provider. If its worked before call your network you may have a sim fault
Feb 12, 2011 | Cell Phones
1) I have XEROX Document Centre 425DC, when ever I take a copy I find black lines on the print , Even on the blank paper 2) When I bought this machine I was told that this machine can be connected to the...
First of all clean the platten glass, also the narrow glass to the left of the platten glass. If the lines are still there after doing a copy,open the upper left cover and look at the fuser heat roller,the lines could be from a toner contaminated heat roller,this can be cleaned with a minerised scowering pad.with the copier switched on press the Key button then # 1 1,touch Enter on the touch screen.touch HSFI tab,scoll down to copies on cru and enter, if the count is above 20,000 the fault could be the cru ( copy cartridge) needs replacing as it is not cleaning the drum.
There is not a USB port on the 425 dc. If the copier has a ESS on top of the engine ( you should see a floppy disk drive slot on the front of the copier) it means it has been converted to a 425 ST, if not it will cost a to much to convert. A xerox 425 ST will connect to a computer. Xerox ST copiers means Networked
Jan 15, 2011 | Xerox Document Centre 420 DC Laser Printer
When feeding the visoneer strobe xp 470 with more than one sheets of documents, the first document goes through with no problems, however, the remaining documents goes through at a faster rate (without...
hi this could be a driver error, try updating the drivers for this, if not un-install the drivers and re-install them and that should sort it out ...hope this helps
Oct 27, 2010 | Visioneer STROBE XP 470
Modem-router connection
ur wireless Network remain unavailable cause may be u have kept it in hidden mode... check the settings once again inside the router
If the problem still persistes... reset the router and reconfigure the same.
Jan 06, 2010 | Computers & Internet
Vista cannot discover XP hosts
This happens if Vista retains history of network devices that once existed on your machine, but do not exist anymore.
Follow the steps at the link below for solution to your problem:
http://techs4u.wordpress.com/2009/08/04/windows-vista-network-connection-cannot-be-renamed/
Jul 30, 2009 | Microsoft Windows Vista Business Edition...
Vista Zombi Eternet Card
If have a problem with Vista and XP workgroup networking.I suggest you find the answer from this website:www.adapterlist.com,It's very cool.
Jul 27, 2009 | Computers & Internet
Where can i get my saeco vienna machine repaired in Houston TX
Purple Turtle Coffee
211 W, Main St
La Porte, TX 77571
281 470 6555
I just picked up my repaired Saeco expresso machine. The people that work here are very professional and spent a lot of time with me showing me how to properly clean my machine. It was about a 30 minute drive east from my house near the Galleria but it was WELL worth it. I say that as I sip on some homemade Latte - yummy!
Nov 10, 2008 | Saeco Vienna SuperAutomatica Coffee...
How can I avoid printing a cover sheet every time we print on a 265 st xerox document center
You have to enter the customer settings, access button then 11111. Scroll around until you find the location to turn OFF the cover sheets.
You also MUST have cover sheets disables on ALL conputers connected to the machine. Somehow if someone on the network has the cover sheet turned on, it will sometimes enable it on the machine also.
It is called BANNER sheet in the memory.
Jul 15, 2008 | Xerox Document Centre 265ST Printer
How to initiate a document scan??
ok...can you scan from the front panel controls, at all? Is this a computer manager fault? Let's isolate this, shall we? you should be able to scan from buttons on front, by placing a doc on the glass, and pressing scan..
Mar 13, 2008 | Panasonic DP190 All-In-One Laser Printer
Xerox Document Centre 265ST Printer Logo
405 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
