Question about RCA P60920BL 60" Rear Projection Television
RCA rear projection 60in powers off
When the unit is plugged in and turned in, it "clicks" inside about 3 times then powers down. no picture any ideas? i checked the fuse in the power unit it seems good
Model # P60920BL
Thanks for the help
  • trichardson7 Feb 10, 2009
    Are there any TV repairs that come to me for free to acess the repairs needed, as this tv is fricking huge and i dont want to call them out for something i cannot afford
    sorry 89102 las vegas Nv area
You need a new light bulb. buy one on ebay for cheap and replace and it will work just as if the tv is new
Posted on Feb 10, 2009
My RCA 60in Television is not working. I does not even turn on anymore. Is there anything I can do to fix it. Its a 2006 model and the serial number is E484C105I. Thank you for your help
The most likliest cause is the Deflection power board PSB260. If the power light comes on briefly and goes out three times then the deflection board is the cause. You can get the replacement ITC222A deflection board PSB260 from www.tvrepairworld.com which has installation instructtions included the board simply plugs in no special tools required.
Aug 23, 2011 | RCA R52WM24 52" HDTV Projection Television
Power light blinks 3 times, no picture
Thats usually caused by the cp150, CP120 or CP114 capacitor having failed. You can get the repair kit by the same name from www.tvrepairworld.com The kit contains the caps and the instructions.
Jun 03, 2010 | RCA HD52W56 52" Rear Projection HDTV
52" rear projection tv has no power and fuse is ok
The clicking noise that you are hearing is actually the power relay. Normal operation by either the remote or the power button on the front panel, you would normally hear a soft click just after the press of the power buttons to turn the unit on or off. When you initially plug the unit in to power, you will hear the same click noise. Being that you are hearing it all the time indicates a failed relay. TV's now a days, or at least ones built during the last 15 - 20 years have different Printed Circuit Boards (PCB). There are PCB's for power (which youre dealing with now), sound,video and so on. The PCB that you need to repair your clicking issue will run you about 80 U.S. dollars for the part plus the average going rate for repair from a qualified service tech. You could purchase the part from Thompson Consumer Products repair and fix it yourself, but be aware, there will be no warranty on the part itself unless an authorized tech does the work. Located on this PCB is the power on/off relay, fuse, usually 4-5 connectors for power to different PCB's (depending on model and features). Now depending on how old the TV actually is, you may want to invest in a newr set, the reason why I say that is, is because the new power unit may and can overload the other boards and cause damage to them and now you have a new problem to deal with( along with more money being tossed down a hole.
Good luck
Sep 19, 2009 | RCA P52926 52" Rear Projection Television
Powers up but no picture
you are having issues with a power supply unit inside upwards of $150 to replace or repair. I would call a local repair man to get a estimate of repair.
there is not special buttons to press for this thing to pop back into action it would need repair. Thanks pls do rate.
Aug 31, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
My tv power won't come on
does a picture come up. from what you have told.. i would think not so. after it goes off does the light flash. this unit has a processor that shut the set down when it "SEE's " a problem..high voltage..crt..theres about 20 to 25 different problems that can cause this.
Dec 09, 2007 | RCA D56W20 56" Rear Projection Television
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
115 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
