Question about HP DESKJET PRINTER, HP OR COMPATIBLE
Printer spooler software will not load all the way because an icon pops up advising printer spooler
    President:
  • 2,110 Answers
GOTO START>Run>type services.msc then go to printer spooler and start the service...
Posted on Feb 10, 2009
Cannot connect with hp printer. a red x appears and says that there is a problem with print spooler
Click Start, Devices and Printers, right click on the Pro 8500a icon for your printer. CLick Properties. From there, click the Advanced tab and choose "Print directly to the printer". Click Apply and OK. From there try printing again.
Report if this works.
Feb 11, 2013 | HP Office Equipment & Supplies
Actually my computer has a problem.everytime i want to print some documents is shows an error named spooler subsystem application error..i have canon LBP 2900B printer. plz help me out
Print spooler is no less than the main master of printing proceeding. Print spooler is a linking section between your PC and printing hardware. Print spooler is the only master of print province of your PC office. Print spooler can inkle nothing and encounter an artificial virus threat which will cease your printing operation and compel your print spooler down on the count. Sometimes to solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
To get rid of it there is a tool named printer spooler fixer.
The link to get that is below.Just copy it and paste in your browser
http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
Jan 07, 2011 | Canon LASER SHOT LBP-2900 Printer
Printer was working, but is not now. All cables are hooked up properly and have been disconnected and reconnected. I have several documents in the memory to be printed, but the printer will not respond. ...
Here are four things you can try; may not have to perfom all:
Check to see if your printer is off-Line
1.Open the Printers, Printer and Faxes, or Device and Printers folder.
To do this:
Windows XP users; Click on Start > Settings > Printers an Faxes or Start > Control Panel > Printers and Faxes.
Windows Vista users; Click on Start > Control Panel > Hardware and Sound > Printers.
Windows 7 users; Click on Start > Device and Printers.
2.Right-click on the printer object (icon), and select Use Printer Online.
3.Microsoft Windows 7 users will double-click on icon, select printer and then de-select Use Printer Offline.
Printer Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation:This is typically an end user error. Hint: Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do:
•Double-click on the print queue icon to open the print queue.
•Click on Printer in the upper left-hand corner of the menu bar.
•Is there a check mark next to Pause Printing?
-If yes, click on Pause Printing to turn off this Windows feature.
-If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Delete print jobs from the print queue
Access the print queue.
Delete all print jobs
• Click on Printer in the toolbar and then click on Cancel All Documents,
or
• Right-click in the print queue and select Cancel All Documents from the pop-up menu.
You can also delete individual print jobs
1.Highlight the individual job in the print queue by clicking on it.
2.Right-click on the highlighted job and select Cancel from the pop-up menu.
IMPORTANT! If a job is stuck in the print queue and cannot be deleted or canceled using the above steps, there may be an issue with the printer spooler that controls the printing options in Windows. If you observe this symptom, it may be necessary to stop and restart the print spooler; then retrun to delete print jobs.
How to Stop and Restart the Print Spooler
Problem:
Unable to cancel print jobs; Unable to print; Print queue is unresponsive; Locked print queue; Unable to print; Cannot cancel print job; Printer driver not responding
Solution:
The print spooler controls print options within Windows. A problem with the print spooler can affect printer driver performance and Windows print queue responsiveness. Stop and Start the print spooler to see if observed symptoms subside or remain.
Method 1: Using Administrative Tools
Step Action
1 Click on the Windows logo start button.
2 Click on Control Panel on the right-hand side of the start menu contents.
3 Click on Maintenance.
4 Click on Administrative Tools.
5 Click on Services. NOTE: You may have to provide an administrator profile and password.
6 Scroll through the list and look for Print Spooler.
7
The following two options are available to stop and start the print spooler:
•Click once on Print Spooler to highlight it, and then click on the Stop or Start links in the right-hand window pane,
or
•Double-click on Print Spooler, and click on the Stop button followed by the Start button.
8 Observe the status column in the Services window to verify that the print spooler is stopped or started as applicable.
Trust this helps to resolve your problem. Please vote.
Dec 29, 2010 | Lexmark X5495 Printer
My printer icon is gone. When I try to install new printer to reinstall it, I get a message that my "print spooler service" is not working??? I went into adminstrative functions and found...
A variation of spooler error is caused by software, giving faulty instructions. Due to this another program intercepts the instructions and confuses the spooler program. It also stops your computer from adding printers, so if this is the case, disable all third-party drivers and software. To stop the error from occurring, follow the steps listed above, but instead of reinstalling the software, you will have to modify Windows' registry. This can be quite dangerous as deleting and modifying entries may just cause even more problems, but in this case, quite necessary. But,instead of blindly poking around your computer's most important files, take professional help.
Nov 23, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Hp printer
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Have a nice day and do not forget to rate please...!
Feb 17, 2010 | HP OfficeJet 6110 All-In-One InkJet...
What does the print spooler service is not running mean?
Things You'll Need:
  • PC computer running Windows XP or Vista
  • Logged in with the administrator account
  1. Go into the Start Menu and click on the "Control Panel" icon.
  2. Double-click on the "Administrative Tools" icon in the pop-up window.
  3. Double-click on the "Services" shortcut icon, which will open a full list of all available computer services
  4. Use the scroll bar on the right side of the window to find the "Print Spooler" options.
  5. Click on "Start the Service" to turn on the printer spooler and allow printing to begin again. Regards
May 02, 2009 | HP PhotoSmart 7550 InkJet Printer
Icon has disappeared and error says printer spooler not running
This is because your spooler service has stopped on the PC.
If you have Win XP, click on start and click on Run.
Type services.msc and click Ok.
From the list, scroll down to Print Spooler.
Right click on this and click on Start or Restart.
Check if you have icon back or not.
Nov 19, 2008 | HP LaserJet 1018 Printer
HP PSC 1315 Printer frozen in "deleting" mode
It seems a Problem with the Print spooler.
You can try a print spooler refresh>
Go To Start> Run> And type services.msc> Ok
In the services window locate for print spooler> And bouble click on the same> It will open the print spooler property window>
Now Bellow service status you should see the Stop Tab highlighted> Click on the same (you will see a small winow popped up and it will close)
Now you will see Start Tab Highlighted> Click on start ( And you will again see a small winow popped up and it will close)
Now stop should be highlighted.
You can try this steps a couple of times untill you see STOP highlighted.
Then click on Apply or Ok and close all the windows and try if it does any better..
IF NOT YOU CAN TRY THIS.
Go to printer and faxes and right click on the printer icon and left click on properties> Go to Advanced> And here you will see ckeck mark on: Spool print documents so program finishes printing later.
Now Select: Print Directly to te printer that will uncheck Spool print documents so program finishes printing later.
Now click on apply and ok and try printing.
If it is better than keep the same settings.
If not you may have to do a complete Print spooler cleanup.
Good Luck
Sep 28, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
Pooler service is not running
If you encounter printer spooler error:
Just follow the instruction:
1. Go to START Menu.
2. Right click My Computer, then click Manage
3. In the right side just click Services and Applications
4. Double click the Services and find the Print spooler
5. Right click Print spooler, then click Start.
6. Go to Start Menu. Kindly check into the Printers and Faxes. If the Printer Icon display. You can start to print.
Other option just reboot your PC.
If you encounter a problem about PC Hardware or Software.
Just feel free to email me at kenny_kenshi@yahoo.com.
Subject: PC Hardware or Software Problems.
I'm Computer Science Graduate in NDU, Cotabato City, Philippines.
Thanks....
Good Day.
Jun 15, 2008 | Office Equipment & Supplies
41 people viewed this question
Ben Johnson
