Question about HP PSC 2355 All-In-One InkJet Printer
HP PSC2355p all in one, cannot use scanner, error messages,
I have tried to reinstall after talking to support, re installed a dozen times, cannot get it to work get error 1310 when trying to run driver, managed to get it to print but now wont scan, driving me mad, an easy solution is needed, please, all i want to do is scan, support is not albe to solve this
HELP !
  • Anonymous Feb 24, 2009
    printer will print but it won't scan. Help!!!!
    same problem
    President:
  • 1,738 Answers
Windows Vista provides a basic set of scanning drivers, also referred to as Windows Image Acquisition (WIA) drivers, that you can use as an alternative to scan a document when you cannot scan using the HP drivers.You can still scan with one of the following methods:
(Click here) workaround
Posted on Feb 09, 2010
Hi Buddy, Can you help me with my HP printer? I keep getting a Scanner Error 8 message and it won't print. Time to buy a new printer?
Make sure the scanner usb and power leads are securely seated
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similiar options also have option to troubleshoot
HP PRINTER DRIVER PACKAGES
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
hope this helps you
Nov 16, 2011 | Office Equipment & Supplies
When i install scanjet 8270 on windows 7 professional.after complete they appear hp solution center on deskotp and photosmart. so the problem is when i try to scan documents or picture or other alse the...
Hi
Please go to the control panel and select the Scanner and Camera, hear you get your scanner, double click the scanner and try to scan the paper, if hear also give the same error then please reinstall your scanner driver,
click hear to download the driver
May 19, 2011 | HP ScanJet 8270 Flatbed Scanner
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Scan button on printer pulls an error message when pressed
you must reinstall the windows and after that install the software drivers and it will work
Jul 30, 2009 | HP PSC 1350v All-In-One InkJet Printer
HP Officejet J5780 scanner communication error
I had this problem too, and after a while just gave up on the uesless HP interface, and went to the simple but efficient Windows Fax and Scan program on the Start>Programs menu.
Jul 09, 2009 | HP Officejet J5780 All-In-One InkJet...
HP scanner will not scan, but will print
reinstall drivers and restart the whole system
May 07, 2009 | HP PSC 2110 Color Printer
HP PSC2355p all in one, cannot use scanner, error messages, cant
Try going to windows update, use administrator options, and download and install windows installer 3.1, and then try re-installing your printer.
Feb 10, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Error message : You need to install or run device software for this feature
Make sure you are logged in as Administrator when installing drivers, in order to write files in the system area.
RDO
Nov 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Scanner/Director problems since installing new ink cartridge
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=45391&lc=en&cc=us&dlc=&product=90764
Dec 28, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
174 people viewed this question
Seeker5211
Seeker5211
