Question about Canon PIXMA MX310 All-In-One Printer
  • 2,110 Answers
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Need to fax, have no instructions, need step by step process.
First of all, What is your home phone service.. If you have a VOID service. Like Vonage - then make sure that your service has been fine tuned for fax usage.
Step by step..
Your MX310 must be plugged in to a Active phone line.
(1) Start by placing your fax materials on the top scan bed feeder. text, picture side facing upwards.
(2) There are 3 choices on your control panel, Choose Fax and the Fax button will then be lit.
(3) Enter in the fax number that you wish to send to.. And hit the Start button on the control panel.
Black or in Color.
As long as you have an active phone line and compliant phone service - you should be good..
Thank you for your visit to
Dec 08, 2010 | Canon PIXMA MX310 All-In-One Printer
MX310 - faxes in memory. Cartridges have been replaced. Error of low ink remains. What is the key sequence to retrieve these faxes?
Press Fax then Menu. You should see Fax Settings across the top row. Use the left/right arrows to select Memory Reference and press OK. Again use the left/right arrows to select Print Document and press OK. Select the transaction (RX) number of the fax you want to print (received faxes start at 5001) and press OK. Then choose whether you want the first page or the entire fax (yes to first page only or no for the entire fax) and press OK. To print additional faxes repeat from the Select RX number. Print the Memory List to find out which fax is which (from the list that you see under Print Document.
Then you can delete these by selecting Delete Document instead of Print Document in the above directions. Then press OK followed by Yes or No for deleting the document.
Finally press Stop/Reset to leave the menu.
I hope this helps.
Sep 24, 2010 | Canon PIXMA MX310 All-In-One Printer
I not send a fax
If your having issues trying to send a fax does it give an error message? But if your not having an issues and need help setting the printer up to send faxes follow these steps.
Make sure you have the telephone line connected into the correct plug-in on the printer.
Go into the menu display on the printer and follow the steps on setting up your printer to send the faxes.
Once that is all done you there should be a button on the control panel that says "Fax" push that.
Now place your paper(s) in the top tray (face up or down depepnding on how your printer wants them. Look for the icon) that you need to fax over to where ever you are sending it.
Dial the fax number with the key pad and then click "send" or "start".
Hope this helps. Have a great day.
Jul 21, 2010 | Canon PIXMA MX310 All-In-One Printer
How to fax by using canon mx310
Make sure in printer list fax printer driver is installed if it is not there then reinstall the printer driver it will install the fax printer. When you want to send the fax from any application then you have to choose print option and choose the fax printer. It will prompt you for dialer window put the fax no and send the fax.
Hope this helps. Please rate my response.
Have a good day.
Mar 23, 2010 | Canon PIXMA MX310 All-In-One Printer
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot receive fax. It goes into memory. LCD reccomends new B-CRT regarding my Canon PIXMA MX310 printer . No problem sending fax,copying or printing.
B-CRT is just asking for a new black cartridge, fax will not print until it's replaced so you don't get a partial fax that you can't get back after printing.
Nov 05, 2009 | Canon PIXMA MX310 All-In-One Printer
MX310, says receiving fax but nothing comes out.
michael885 -
Your unit has a certain amount of memory designed to store faxes... if they are stored there, here are the instructions for retrieving the fax's from the memory:
(I found this at:
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Aug 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Report of fax
Hey renzo737 - Follow these steps to have your machine print a report after you send each fax:
1)Hit the Fax button, then the Menu button.
2)Press the < and > buttons to scroll until you reach
TX Settings. Hit OK.
3)Use the < and > buttons to scroll until you reach TX REPORT.
Then hit ok.
4)First you want ATTACH TX IMAGE and then you want
PRNT FOR EACH TX.(it may also say as TX REPORT)
On your machine under TX report it may just say PRINT ERROR ONLY, which means only print if there's an error, or the PRNT FOR EACH TX. You'll find it easily. You want the print for each tx option. This will print a report and give confirmation that your fax went through after each fax. If you have any problems understandind this or need more help just give a shout.
If this solves your problem PLEASE rate this as fixed. Like I said if you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good one.
Jun 30, 2008 | Canon PIXMA MX310 All-In-One Printer
Help with setting up my cannon mx310 fax machine.
here you can download (under "download now" near the bottom of the page) the manuals you have lost.
Hope it helped you!
Dont forget rating.
Jan 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
54 people viewed this question
old marine
old marine
