Question about HTC Touch Diamond Smartphone
HTC Touch HD - Vibrate function
Hi, anybody knows how to make sure the HTC Touch HD to work on "vibrate and ring". I tried all vibrate functions... vibrate only, vibrate and ring, vibrate then ring; all type on "vibrate" not working. Any faults on the phone?
Thanks. MH
The '********" is a little motor that spins with an offset weight. It sounds like the motor is stuck.
Posted on Feb 10, 2009
My speaker on my htc inspire will not work it was working fine then it quit on me how do i fix this i can't even hear a ringtone my vibrate works
You might need a software update here
HTC Inspire 4G AT News download Support HTC United States
HTC Inspire 4G AT SETTINGS SERVICES FAQs Support HTC United States Online support
Jan 16, 2015 | HTC Inspire Cell Phone
My phone has lost its sound and when someone rings it will only vibrate then when i answer, i can hear them but they cant hear me, I have checked and it is not on silent.
First make sure the phone is not on silent,
Try changing the ringtone, go into phone->options->sounds, make sure type is set to ring, if so select a different ring tone.
May 31, 2011 | HTC Touch P3450 Smartphone
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
S740 ring and vibrate
You can't. Only vibrate or ring only. Maybe some 3rd party app may do that.
Oct 15, 2009 | HTC S740 Smartphone
Vibration for text message
I use an HTC Touch. Hopefully the menu should be the same in Touch HD as per the Touch. Try this..
Start -> Settings -> in the Personal tab, click Notifications -> u might see 2 tabs -> select Notifications tab again -> select an Event (here it is incoming SMS) -> below you'll see the Vibrate option -> tick on it to enable it -> Select OK to save.
Hope this helps, If so, rate me.. thanks - billa..
Sep 06, 2009 | HTC Touch HD Smartphone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
HTC Touch Pro Won't Vibrate
So you having problem with vibrate capability?
Try this:
1. Make sure your phone not in charging (it won't vibrate for several phone like e.g. NOKIA)
2. Have you dropped it? If yes, immediately contact the customer service.
Hope this will help! PM me if there's any questions =]
Jul 07, 2009 | HTC Touch Pro Smartphone
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Jun 14, 2009 | HTC Touch P3452 Smartphone
How do you turn on vibration for ring tone?
go into profiles. there is a setting for meeting. click on this hit activate and ok. it will set it to vibrate. if you have the three page menu function it is on the second page. you will see outdoor etc. but to set it to vibrate you want the meeting tab.
Apr 05, 2009 | Dual Electronics CECT P168 Cellular Phone
HTC diamond no longer Vibrates
The vibrate function of a phone is just a simple motor that pulses back and forth, creating a vibration. Just like any other motor, these can burn out. If the phone is still under warranty, you should be able to get it replaced. If not, an electronics repair shop may be able to fix it, but depending on parts and labor, you may be better off buying a new phone.
Mar 25, 2009 | HTC Touch Diamond Smartphone
HTC Touch Diamond Smartphone Logo
409 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
