Question about Kenmore 43142 Front Load Washer
Kenmore front load washer won't start
I have checked all the connections and the washer won't start.  Someone said it might be the lid switch, but discovered that's not the problem.  Any suggestions on where to go next?
    Scholar:
  • 165 Answers
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
bad start switch, sometimes the contacts in the start switch will arc and burn causing starting up problems.
Posted on Feb 10, 2009
  • 1,029 Answers
Is your washer getting power? The first things to check if your washer suddenly stops working are your circuit breaker, lid switch, or fuse box. After making sure there is power to the appliance, you can start troubleshooting other problems. To verify there is power at the outlet, try plugging in a small electric appliance such as a hair dryer or radio.
Sometimes the motor will overheat and then requires a cool down period before it will restart.
Is the machine in a pause cycle? Is the lid up? Washers will not spin or agitate if the lid is up. There is a lid switch probe that can sometimes become dislodged. This is generally a little plastic piece that is in the hole under the lid on the washer. This probe activates the lid switch when the lid is put down. Manually advance the timer if the pause is too long.
There are some washer models out there that will not run at all until the water is filled to the level that has been selected. Sometimes the mechanical timer knob on certain washers doesn't exactly line up with the graphics on the control panel. You can try advancing the timer slightly and pull the knob out again to see if it will start.
  • Starnley Johnwells
    Starnley Johnwells Feb 10, 2009
    hope this helps pls do let me know
    Starnley Johnwells Feb 11, 2009
    hope this helps pls appreciate by rating as fixyaa
Kenmore washer front load 417 wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My washer won't fill with water
Check the water inlet valve,kinked water lines,or clogged inlet screens.Is the lid switch working?
Dec 29, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer fills up then stops?
check the door safety switch,, if it isn't working it won't continue,, check around the door ( lid) you will see the switch, its usually under the lip, once you get to it, you can go to the connector, and unhook it,, and on the side away from the switch, place a jumper wire on the connections,, it should start, if so , replace that switch
Aug 12, 2011 | Kenmore 24042 Top Load Washer
I have a Kenmore 60 series heavy duty washer. It will wash and drain in all cycles just fine, but it won't spin. It sounds like it wants to spin but it wont.
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 22, 2011 | Kenmore 24032\24036 Top Load Washer
I have an elite kenmore top load washer. With the lid closed the washer will fill with water, but the wash or spin cycle will not start unless the lid is gently pushed down on the upper left side of the...
Lid switch has gone bad...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 22, 2010 | Kenmore Washing Machines
I have a kenmore top load washer that stops & starts during wash agitation cycle and then sits with water & doen't go to spin cycle
check the lid switch,open the lid and use a pen or screw driver and touch the lid switch and listen for a click,if it doesn't click change the lid switch,if that's ok check the coupling,take off the front of the washer,take off the pump and then take out the two screws on the clamps that hold the motor in place,when you remove the motor you'll see the coupling,
Oct 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model number 110.22642100 won't spin
check the lid switch. if the machine is agitating and washing but won't spin it is probably the lid switch. this is the switch on the top front right of the machine with the lid open. you will see two phillip head screws holding it in place. easy fix is to unplug machine and take screws out of swith, clip wires and use wire nuts to connect another switch.
Apr 07, 2009 | Kenmore 22642 Top Load Washer
Kenmore 43142 Front Load Washer Logo
1,248 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
