Question about Frigidaire ATF6000ES Front Load Washer
Fabric softenor doesn't work
Gltf1040as
  • 77 Answers
Hi, inside the lid there is a plastic valve assembly, i think this may be the cause of the problem replace it. hope this helps
Posted on Feb 10, 2009
Aeg Manual 86810
Remove soap drawer and give a good clean
Oct 30, 2013 | Washing Machines
Singer model 620 sewing machine needle pokes holes in fabric but doesn't sew with the thread?
try changing the needle--make sure it's the right needle for the
fabric being sewed
rethread the machine top and bobbin
make sure the bobbin is inserted into the bobbin case
it's also possible that the machine could have a timing problem
and needs to be checked
Feb 12, 2013 | Sewing Machines
Thread is braek in between bobbien for cloths
Clean the bobbin and chase. Look for any bits of stuck thread. If that doesn't work, re-thread the top and bobbin. If that doesn't work, take the needle out and re-insert making sure it is the correct way.
Aug 26, 2012 | Craft Master 4400 Mechanical Sewing...
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
Thread doesn't catch when sewing heavy fabrics with White ESP sewing machine.
make sure the needle , thread, fabric are compatable with each other
the tension must be adjusted also
Mar 29, 2012 | Sewing Machines
How I fit the XL seat for quinny buzz. There doesn't seem to be anything to fix it onto?
Hi
The infant stage seat fabric that the Quinny Buzz was originally fitted with is on a sub seat (seat frame) that is then clipped into the chassis.
Remove the infant stage seat fabric from the sub seat and replace with the 2nd stage seat fabric.
Mar 28, 2012 | Quinny Baby Gear
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
Kenmore 1764180 will not advance fabric, feed dog just doesn't appear to be moving. This has been happening intermittently but now will not advance at all and have been unable to get it to work. Any...
How old is this machine? At zero setting of stitching length the fabric wouldn't move. There may be problem in stitching length mechanism or the fabric feeding mechanism is wornout.
sonsunny
Jun 18, 2011 | Sewing Machines
Frigidaire ATF6000ES Front Load Washer Logo
43 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
