Question about Dishwashers
No water to dishwasher
When i try to turn on the dishwasher the motor work but no water is comming in
  • Anonymous Mar 11, 2009
    The element gets hot and you can hear the motor but there is no water coming into the machine
  • Anonymous Apr 13, 2009
    dishwasher turning on, but no water comes in
    Scholar:
  • 165 Answers
There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Feb 10, 2009
. The dishwasher fills with water but will not
Same problem here. It's been a while since we used it. HDA 3440GO2SA. I think I've narrowed it down to the motor seizing. I get 12.2 ohms on the windings and a local tech says the windings are good then. Some decent troubleshooting videos here http://www.appliancehelponline.com/dishwashernotrunning.html. Turn the breaker off for the unit (so you have no power), remove the bottom panel and kick plate. take a screw driver and try to turn the motor fan blades. If it turns really hard keep turning it until it loosens up. If it turns freely, pull the plug, test the power coming in with your multimeter (requires turning breaker back on, of course, but after the leads are inserted in the plug). You should have around 120 volts with the door switch activated and wash cycle on. Anyhooo...I plan on trying to pull the hub and clean it up, put some di-electric grease on it and re-assemble. If that doesn't work then I'll debate whether to spend 150+ on a new motor or just get a new dishwasher...lol.
Jul 31, 2011 | Hotpoint 24 in. HDA3400G Built-in...
Dishwasher draining / emptying of water
Drain line/air gap
Pump
Belt
Motor
Timer
Oct 27, 2008 | Frigidaire Dishwashers
My dishwasher came on fillied up with water then would not do anything else.However it sounds as that it is humming like its trying to run.
Disnconnect the power to the washer and remove the front-bottom plate. Reach in and try to turn the motor by hand. Often if you turn it by hand a few rounds it will go back to work. If it doesn't go back to work or it locks up agian anytime soon replace the motor. http://www.appliance-repair-it.com/dishwasher-repair.html
Sep 10, 2010 | GE Dishwashers
DW5700P1 dishwasher must have stopped running last
A lot depends on at what point the dishwasher stopped working.
Have you tried to turn the mains power off and on again and then try one of the short cycles.
I would suggest if water is not draining, then empty with a small pan and check filter for blockages. Also good idea to check there is no blockage on the drain side.
A good site to check is
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
Please post a comment to let me know what you find.
May 29, 2010 | Frigidaire Dishwashers
Kenore Elite Dishwasher
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Sep 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Have model PLDB999AC0 water is not coming on
Is the supply turned on and power applied to the dishwasher? Make sure you've turned the angle stop to open the lines and supply the dishwasher with water. If this is a new problem and it had previously been working alright, then you're looking into a problem with the timer or motor. The motor contains a solenoid that activates a gate to allow water to flow into the dishwasher basin. Remove the kick plate and watch the motor as you allow the dishwasher to run it's cycle. You'll see it go up and down and probably hear a loud hollow sonnd when it activates. Also, make sure the motor is running, and if it's bound, try using a screwdriver to jump start the motor. If it starts up, this sometimes fixes the problem, but it may just put off the inevitable replacement.
Jul 08, 2009 | Frigidaire Dishwashers
Dishwasher will not drain
Thanks.
Jul 02, 2009 | Maytag MDB9600A Jetclean II Built-in...
Kenmore portable dishwasher not working
if you can get underneath it try spinning the motor manually (after turning off the circuit breaker). sometimes the motors on dishwashers get jammed.
May 29, 2009 | Kenmore 22422 Top Load Washer
Maytag - MDB4800AWB - water will not drain
If water is not draining, check first that the drain hose is not obstructed. Try also advancing manually the timer/[programmer.
If water is still not draining, it may be a faulty drain pump, aproblem with belt/motor , or a defective timer/control panel.
Drain line/air gap
Pump
Belt
Motor
Timer
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon."
from The water doesn't drain from the machine
Sep 27, 2008 | Maytag 24 in. MDB4000 Built-in Dishwasher
Dishwashers Logo
634 people viewed this question
Top Dishwashers Experts
Owen Barnes
