Question about Soyo DYLM1986 Monitor
Syncmaster paower button blinking and no display
Samsung 204b syncmaster. Came home and found montior all black and just the power button blinking. Tried re-booting but no go. hooked up my old crt monitor and everything looked good. What could have happened?Can I do anything?
I came in to work this morning and blue power light was blinking and the the letters DVI were very faintly flshing in the upper left corner of the screen. I've tried unconnecting and reconnecting all of the wires - nothing seems to change whats happening...
Not sure what to do.
  • Anonymous Mar 06, 2009
    mine was doing that after trying to reboot and other various things connected the old moniter up and everything was ok happened 3 or so times before finally couldnt get it to work again opened up the monitor and the power card had shorted out or been zapped by a power spike
  • 1,602 Answers
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Posted on Feb 10, 2009
ONLY BLINKING POWER BUTTON ON THE DMONITOR. NOTHING ELSE IS THERE.
This is a common problem with the Samsung 204B units that have been in service for a few years. Parts called capacitors in the power supply start failing and causing the board to not start correctly. The blinking power button is just the power supply restarting over and over. The monitor is easily repairable, you just need to replace the 5 capacitors that have failed. Here is a link to a page that shows how to open the monitor, get to the power supply board and what to replace.
http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung syncmaster 204b not turning on- My monitor's problem was when it switched off, the only way to make it work was switching off main power, and turning on again, then it would come back on...
in near your monitor u find any metallic product than you please remove the the monitor and plug in another side if your problems is steel not solved than you please contact samsung service center regarding this issue...........
Dec 17, 2010 | Samsung SyncMaster 204B (Silver, Black)...
My SyncMaster 204B 20.1" suddenly died. One moment it was working and the other it just turned off. It does not respond to power on/off. I opened it and looked at the board: the capacitors look intact, the...
Caps have completely flat tops, bad caps can also look normal but can have high ESR (Equivalent Series Resistance).<br /> What voltages are you getting at the secondary DC power supply side measure directly on those caps?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"> <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | Samsung SyncMaster 204B (Silver, Black)...
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B The blue power button is on but the screen is black. When I turn it off and back on it shows the screen for a second then goes black. Can you please help me. Thanks
Got the same problem, happened yesterday for me, Did some research and it looks like its bad capacitors in the back, check out this page for more information... i'm taking mine to an electrician to fix today... luckily he's related and should be able to fix it on the cheap...
http://pavel.kirkovsky.com/blog/2009/03/samsung-syncmaster-204b-repair/
Apr 02, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204 Samsung monitor has no power
Have you tried to plug it in else where?
If you did and still same problem then from what you said I was hopping that it wouldn't be your problem, but you will need a new monitor.
Mark
Mar 29, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Black screen; blinking power light
are using dvi cable did u try to hit the input botton on screen itself thx nick
Feb 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW.
Oct 23, 2009 - This is how it went for me..I have a Samsung SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. - I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Soyo DYLM1986 Monitor Logo
845 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
