Question about Kenmore Freezers
Runs -6far. for about 2 weeks, then alarm sounds, unit is warm.
Sometimes when i turn unit on the fan does not start, when fan does go it cools very fast, the first time the alarm went off there was alot of ice on evaporator, i let unit sit for about 8 hours unit worked great for about 2 weeks. the second time alarm sounded there was very little ice on evaporator, i let sit for 8 hours then turned unit on, it seemed to be cooling but fan was not on. tried to turn on again fan worked but looked like speed was changing.
    Scholar:
  • 165 Answers
Its the problem of the motor which runs the fan.that motor needs replacement.a very chance it can be possible that the motor is perfect but the wirings from the motor which connects to the fan are faulty and got cut in between.but it can be possible.so first check out the wirings if they r perfect then its faulty fan  motor.get it replaced. thanks.
Posted on Feb 10, 2009
Upright freezer door was left ajar. The alarm keeps sounding, can you tell me where the reset button is located.
Hello Deena;
My name is Peter. I am a retired field service refrigeration technician.
There is no reset for the alarm. The alarm goes off when you are not maintaining temperature.
During the time the door was ajar, warm air got into the freezer either icing up and locking the cooling fan or forming a block of ice on the cooling coils (Restricting cooling air flow.)
The best thing you can do, unless you want a $300.00 plus service call to defrost everything, is to turn power off to the freezer. Open the freezer door. Have plenty of old towels to soak up the water in the bottom of the freezer as it defrost.
You did not provide a model number which is located on the inside wall of the freezer. Every 8-10 hours your freezer will completely shout down for 20-30 minutes where only the light works and the defrost heater turns on. The ice build up is too much for the defrost heater to handle.
In some freezers the defrost mode is in the control board, in others it is a separate component that you can repeat trip using a flat head screw drive.
Jan 26, 2016 | Freezers
Are "door open" alarm won't stop beeping.
Try disconnecting the power at its source, then reconnecting it.
May 17, 2015 | GE FUF14SVRWW Upright Freezer
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
On normal operation my freezer alarm will not stop bleeping.The only way to silence alarm is to switch to Fast Freeze ,however the compressor runs contually ,even after 24hrs and switching back to normal...
Have you cleaned the condenser grill and made sure you have plenty of air flow around the unit? It might also be time to take the food out and completely defrost your freezer! Since you do have an ice build up on your evaporator grill.
Jul 31, 2011 | Whirlpool Freezers
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
High temp 20-29 F Frequent high temp alarms
check condensor fan if it has one. if not unit may have sprung a leak some where
Apr 10, 2010 | Freezers
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
1999 Kenmore upright freezer alarm lite on, how to diagnose problem. Sealed unit and see no fan by compressor? Lower coiles seemed cold w/ some ice but higher shelves(coils) not so cold? 23 year Master...
the reason there is no fan on the outside is because the outer shell of the unit is the condenser. the unit does it have a fan on the inside? also how does that gfasaket on the outside of the door look like? let me lknow
Jan 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Unit not freezing , evaporator fan wont run
If this is a Bev-Air, don't think the door switch will control the fan. At the evap, there is a temp sensor called a fan delay. When unit goes into defrost mode, this warms up. Some also serve a dual purpose. It will terminate the defrost cycle at a certain temp., say 51 degrees or so, at the evap. Anyway, when unit comes out of defrost, it keeps the fan off so it allows the evap to cool quicker and to prevent circulating warm air. This could be your problem. Not a hard fix but they can be a pain sometimes. Outside chance that the unit is low on refrigerant (freon). This will not let the evap get cold enough to trip the sensor back into position to turn the fan on. Good Luck. Restaurant Parts and More carry alot of Bev-Air stuff. 1-888-814-1110. Ask for Rick
Oct 09, 2008 | Beverage-Air 23.1 cu. ft. / 654 liter...
Freezers Logo
90 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
