Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
No video with HDMI port
I have a panasonic PT50LC14 and the cable box is connect to the HDMI port in the TV. The audio is OK but nothing is show in the screen. In the troublwshooting disconnect the cable box and reset it and also did the samething in the TV but not work. Connect the cable box to a LCD Samsung to the hdmi port and works ok. Base on the last troubleshot for me is the HDMI port or something is happend with the high definition video. The cable box know is connect to the component video and audio is connect RCA port but is not same. Someone have a solution or idea how resolve the porblem.
Thanks
  • russell harps
    russell harps Sep 14, 2015
    we bougth a converter to change hdmi to rca.got it at radio shack works good for us.
  • 37 Answers
Try 2 things, first use the rgb cables or video (yellow) cable and plug it into the tv using one of the imports..(vid 1,2,3 etc...) and see if that works. then check to see if you get a picture by not using the cable box, by pass it and connect it connect it in the uhv channel. also make sure you have it on the right input of the tv (meaning scroll through the input button on your remote to find the picture...i've done this a million times). still no picture try your dvd player input and if you have a vhs input see if that works. if it is the hdmi input...to be honest it's expensive and a pain to replace...
Posted on Mar 12, 2009
I conect my lenovo laptop Y 410 with Panasonic THP42C10 D for Vidio There are no sound in TV
Hi dr_piyushpat,
I see that you conencted your Lenovo Y410 to a Panasonic THP42c10 LCD TV, see details below.
*The Audio will dpened on what cable connection you have from the Laptop to the LCD TV,
*You have Y410 I do not think that HDMI will be an option.
*I believe that you are using the VGA port on the Machine for an extended Video.
*The Audio will really not be coming out of the Panasonic TV if you are using a VGA cable since that is only for Video you will need an audio cable Jack that will relay audio from the Laptops Audio Jack to the Audio Jack of your Panasonic TV thsi is the only way you can get audio out from the Laptop since you are conencted using a VGA cable.
* do not think that HDMI is present on your Lenovo Y410, but if ever you may have that connection/port the way to get Audio from an HDMI conenction is to change the audio PLayback properties and selct HDMI as the default device for the Audio to work using HDMI.
I hope that this helps.
have a nice day,
mvincentc
Feb 13, 2011 | Lenovo 3000 Y410 Laptop
I am having trouble connecting my Panasonte SC-BT230 to my cable box and my TV. Do i connect my cable box to SC-Bt230 than to my TV or my SC-BT230 to cable box than to TV
Here are a few ways to go about this.
connect the cable box hdmi (if Capable) to the panasonic hdmi input. Then connect panasonic hdmi out to tv hdmi in. The easy thing about this setup is that you only need the two hdmi cables because they carry both audio and video.
If your cable box or tv are not hdmi compatible, Then connect video output from cable box directly to your tv, and send an audio feed from your cable box to the panasonic.
Hope this helps,
Good Luck
Jan 07, 2011 | Panasonic Home Theater System System
How do I connect my Panasonic SC-HTB500 sound bsr to my Panasonic TH-42PX75U television with an HDMI cable?
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
Dec 26, 2010 | Panasonic Televison & Video
Got a svga/hdmi cord and hooked up for my panasonic viera plasma to my computer but nothing shows on my component 2. also wondering if i'll need a cord for audio - i have double red/white/yellow...
You probably would need the extra audio cords seeings as normal svga connection won't suppost sound streaming. mixing and matching connections is always a pain to perfect.
If you are using the HDMI end on your plasma, then you will have the video show up on the HDMI channel. Then get an RCA red and white pair - 3.5mm jack and plug the jack into your PC's audio connection port and the RCA's into the Audio In ports in the back of the TV.
Once done the TV should display video and play sound from the PC. Failing this, try a few different configuration but always keep the audio plugged into the same Audio in port on the TV. Bacause then you at least know the channel that the audio works on ;D
Hope this helps mate, any more q's just ask!
Nov 23, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Only one HDMI port on new receiver/dvd player
Chances are good that your panasonic would not support HDMI 1.3b firmware and you would loose audio or video anyway. If your Panasonic has digital inputs, ie. coaxial digital or optical, run audio to your receiver and HDMI direct from Cable box/ DVD/other source to TV. On the TV settings menu, turn the speakers "off". If you need further help, post a comment and I can help you more
Oct 14, 2009 | Audio Players & Recorders
TH-42PX60U All output ports works but HDMI ports
Problem is with your ISP/Cable Company accepting the installation as one with HD clients, which while
not necessarily costing you more, must be specified to the cable box by your installer.
Make the call.
Apr 17, 2009 | Panasonic TH-42PX60U Television
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
423 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
