Question about Sony Ericsson W850i Cellular Phone
Hide my number
Trying to hide number but it keep going back to network default
  • 52 Answers
If you are going in and hiding your number and it's going back then it's something with the device...do a master reset..if doesn't work...get the device replaced. Something is wrong with the device
Posted on Feb 11, 2009
Handset AT&T Some of my out going calls, I receive this statement. Not accepting annonomous calls, please unblock. How do I unblock? Could not find info in my manual.
under call settings, you may have a menu additional settings. what you are looking for is caller id. it's most likely set to hide number, you may want to set this to network default or show number
Sep 04, 2013 | Cell Phones
Tip
To make your number to appear as private
1 There are many ways to enable call blocking. If you have an old phone, skip to step 52 First, look around for a option under your phone's call settings menu called "Show/Hide My Number3 When you select it, it will most likely be set to "network default," which means that displaying Caller ID information would be dependent on your carrier's network setup for your mobile number. Change it to "hide number" to have the phone ignore the network setting and stop reporting your caller ID information.4 Check if it works by making a test call. You may also need to turn your phone off and back on for the change to become effective5 If it does not work or the option is not available, begin your call with *67, if you're in North America. So, for example instead of dialing 1-718-555-0123 you would dial *6717185550123. If in the United Kingdom and Ireland, then dial 141. If in Australia then dial 1831 before the number, for example.are helpful or not ?
on Apr 28, 2011 | Cell Phones
Default admin password
  1. Enter your user name. If you didn't change the user name during installation, enter admin in theUser Name field. [Show Me]
  2. Enter the password you entered during installation and click OK. Additional characters will appear to be inserted as you enter your password. This is designed to hide the number of characters in your password.
    • Note: If you didn't change the default password when you set up your router, it may have been changed to your router's serial number to provide greater security. You can find your router's serial number on a label affixed to the bottom or back of your router.
    • Note: If you can't remember your user name or password, you must reset your Verizon MI424WR router to the default settings and reconfigure your home network.
Feb 23, 2012 | Actiontec GT704WG Wireless Router...
How to hide my number in samsung e2121b
Hide or Display Your Number on Samsung GT-E2121B
1.Go to your menu and select Settings (round gear wheel thingy).
2.In the settings environment, select item no 6 - Application
3.In the Application environment, select item no 1 - Call
4.In the Call environment, select item no 1 - All Calls
5.In the All Calls environment, select item no 1 - Show my number
6.This gives you the following three radio button options:
i.By network
ii.Send
iii.Hide
Select iii. Hide, then exit to return to your phone interface. All calls will not display your mobile phone number to the recipient.
To reverse this and display your number in subsequent calls, repeat the whole process and at step #6, then select i. By Network. Your mobile phone number will now display to call recipients for all calls.
Jan 02, 2012 | Samsung Cell Phones
Internet connection, lost wireless connection. Tested all hardware, all working. Wireless network shows "disconnected" or "unplugged". Cannot "ping 192.168.1.1. Have Broadcom 440 10/100 integrated...
Try and connect the router directly to a pc with a cat 5 cable, then try and load the settings page. Make sure that you do not have you SSID hidden, this is the name of your device that is broadcast. if it is hidden you have to have everything set up on the computer exactly the same (case sensative) or it is difficult to connect, you can hide it again after you establish a good connection. You may try pressing the reset button on the back. I hope this helps, good luck.
Sep 22, 2009 | Linksys Wireless-G Broadband Router
Managing incoming calls
HI,
Nokia 6111 and Nokia 6300 are the ultimate phones and I like it very much.
SOLUTION:
1.Go to "menu". 2.Then select "settings" by scrolling down. 3.Inside "settings" menu, go to "call settings". 4.Inside call settings we can see various options to select that contains reject/show busy/divert.we can choose any one from them.
SOME TRICKS: Hiding your Mobile/ Cellphone Number
1.Go to: Menu > Tools > Settings > Call > Send My Caller ID >
"'Yes', 'No' or 'Set By Network'" to follow the default settings of your home network.
It works only with very few network who provide you facility of “Private Number”
Apr 17, 2009 | Nokia 1100
I have sony ericsson k750i i have problem my phone if i want to call someone but i don't want let the people see my number in there caller id. when i go to setting and click call it shows me show or hide...
The problem is not on the phone but with the network provider. some network providers dont alow you to hide your caller i.d for security reasons
May 18, 2008 | Ericsson Cell Phones
Cant change show my number settings back on my g600 plz help
hi there i don't exactly know the settings of samsung but the best way is to default all the settings by reseting.
to reset just inter the code *2767*3855# without simcard.
peace!
Dec 14, 2007 | Samsung SGH-D900 Cellular Phone
I am Looking for Encryption Key/Wireless Security Password
Hi, you will need to connect the laptop to the router with the ethernet cable for the moment.
Click on start button, click run, type in cmd then press enter.
Black screen appears, type
ipconfig /all press enter
scroll up afterwards look for default gateway you should see one with a number like 192.168.1.1 for example
once you write down that number close the program
load internet explorer
where you type www.ebay.co.uk for example
type in the number 192.168.1.1 or whatever the default gateway is.
hit enter
it will load the router menu
type in the username and password when it asks.
usually admin and admin, or admin and password.
Once into the main screen, click wireless settings. and you will see the WEP or WPA network key in there,
Write it down, its case sensitive.
unplug cable, try connecting type in network key
Have a nice Christmas
John
Dec 12, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connection problems
Your query "is there anyway...remove...wireless network connections 1-8 ...solely on 3?"
In your Device Manager, delete all instances of the wireless network connection except # 3.
However in WinXP, the default setting of the Device Manager is to  hide certain devices (like printers, non plug & play devices and removable devices not currently installed/connected).
In your Device Manager, pls click on "View", check "Show Hidden Devices." Thus enabled, all hidden devices (whether multiple or not) will now be displayed.
Hope this be of some help/idea. Post back how things turned out or should you need additional information.
Good luck and kind regards.
Oct 30, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Sony Ericsson W850i Cellular Phone Logo
73 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
