Question about Kenmore 22422 Top Load Washer
Hot water flow
If i do a hot water wash , the water flow is fast and them slow & fast etc.
Is there a reason for this? Should I be looking for solution ? Is the hot water not hot enough ?
    President:
  • 1,902 Answers
Check the water pressure, Are you having pressure problems anywhere else? IE shower, sink anything like that?
Posted on Feb 10, 2009
My maytag washer model lat8006aae hot water flows in slow. I reversed water supply lines, no change, replaced water strainers and new water lines, still slow flow. supply lines, inlet water valve
It is possible the hot cold switch is flawed and stuck on mix of hot and cold I would have the inlet valve checked with a multi meter they can also check it for u at most appliance parts stores
Feb 07, 2015 | Maytag Washing Machines
Slow hot water fill on speed queen washer
the valve filter is blocked up
turn off the hot water supply and remove the hoze from the machine end valve inlet
in the inlet is a small filter remove it and clean it
if its not too bad perhaps the valves solinoid coil has shorted turns
and wont open fast or fully
check the outlet preasure of hot water from the hoze to a bucket
see it flows fast ..
Apr 03, 2014 | Speed Queen AWS45NW Top Load Washer
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
COLD WATER IS RUNNING SLOW INTO WASHER. THERE IS PLENTY OF FLOW IN THE HOSE AND NO KINKS AND THE SCREEN IS CLEAN. HOT WATER FLOW IS FINE. WASHING MACHINE MAKES A GROANING NOISE WHEN COLD WATER IS ENTERING.
Based on your description, the selenoid is bad.
The same device feeds both cold and hot water - so locate your machine model number and year.. and look up the replacement incoming water selenoid part number. You will need to purchase it and replace it.
If your machine is under warranty, call their Customer Service line and report the water flow/noise problem.
Please let us know your findings...
-Jim
Oct 17, 2009 | Washing Machines
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
51 people viewed this question
Sal De
fordexpert
Robert Rankin
