Question about Dell 924 All-in-One InkJet Printer
Paper keeps misfeeding in Dell AIO 924
I can't get my paper to feed right into my Dell AIO 924. It goes in crooked and when I take the paper out I notice on the right lower side it's a little crinkled. Any suggestions?
  • Well. I have tried everything and just gave up. I found a great deal on a laser printer on E-Bay and have purchased it. I will never buy a Dell Printer again.
  • 512 Answers
I first wonder if you have children. if so, then open the lid and/ or look in the paper feed area for plastic tools, band aids, etc. (worked in tech support and once had a gerbil stuck in a printer by it's tail! OUCH!)
if you can't see anything, then take a letter sized piece of poster board and try to run it through, that should clear any foreign debris (such as paper clips or pieces of post-it notes that you may not be able to see) good luck!
Posted on Feb 28, 2009
What is causing misfeeding?
Either the paper is slipping and not reaching the sensors at the right time. or a sensor flag is broken/missing/out/stuck and the device stops the paper thinking there's a jam. Clean all the paper feed rollers with a clean lint-free towel and water only. See if that will improve the grip of the rollers. If they appear shiny, replace the rollers. They are too worn out to continue working properly.
Feb 29, 2016 | Xerox Phaser 6360 Laser Printer
My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
My dell 944 is misfeeding on the left side of the paper. How do I repair the device?
Check for foreign objects in the paper path (I did a lot of these and pulled everything from hair curlers to dead mice!), if it's not this then contact Lexmark for a replacement paper roller, this is a common problem with Lexmark printers (Dell just rebadge them).
Oct 30, 2009 | Dell 924 All-in-One InkJet Printer
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
Paper ALWAYS feed crooked.
Defective rollers or you have something stuck in a corner...look carefully or try cleaning the rollers with robbing alchool (remouves grease)
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
Paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
Paper won't feed and get's stuck
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
Good luck..
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 30, 2008 | Dell 924 All-in-One InkJet Printer
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
129 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
