Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Power Supply Port Burnout
My brother and I both have ze5000 laptops we bought back in 2002. Back in late 2005 we both started having issues when we both mistakenly used the power adapters for another HP Laptop. I maybe used the adapter twice for a short time.
Anyways, not too long afterwards, I noticed the yellow ring on my adapter turned brown, like it had been burned. The pin on the power port had also become loose.
Over the course of over a month the adapter became more and more temperamental until it burnt out.
The only way I can use this laptop now is to use an external battery charger and swap out the laptops. I get about 45 minutes per charge and have to suspend my work to swap out the two batteries. Kind of a big pain.
I want to get it working again. Is there a way to get regualr power working again?
This is not a big deal if I can't get it working. I have a tablet which is equally as old and a new desktop at home. I have a some old files and a few programs to which I have lost the installation discs on that machine.
  • HP Master
  • 5,660 Answers
1) You need to replace the DC Power Jack. This is the port on the laptop where the AC adapter (Charger) plugs in. {Power port}
Most so called repair shops won't touch this. (Notice I stated so called) They will want to replace the entire motherboard. {Geeks are us}
A bona fide computer repair tech can replace the DC Power Jack. Cost of jack? Around $10. Repair bill? From $50 to $125.
[Entire laptop needs to be disassembled, down to the bare motherboard in the tech's hand. Precise de-soldering, and soldering skills, are needed for the DC Power Jack replacement. Reassemble laptop.
This gives you an idea of what is involved,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6500-dv6600-dv6700-dv6800-notebooks/
[Older HP Pavilion DV6500 through DV6800 models]
DC Power Jack replacement,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
2) Replace the AC adapter. If the AC adapter has a separate cable from the power unit, to the laptop, then by all means just replace it. May be more of a headache, then just buying a universal AC adapter.
Barring none of the above is a feasible approach for you, and you wish to save the information on the harddrive, of both your laptop, and your brother's, I would suggest an economical external enclosure.
Remove the harddrive, and install it in the external enclosure. The enclosure has a USB cable, and is plugged into any available USB port on a separate computer.
(Desktop?)
The HP Pavilion ZE5000 series of laptops, (Business Notebook's), use an IDE (PATA) harddrive.
It is 2.5 inches across in width.
(Desktop harddrives are 3 and 1/2 inches across in width)
This is one example of a 2.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3169580&CatId=2782
To remove the harddrive, I'll need to know the exact Product Number.
(P/N)
This is on the bottom of the laptop in a white Service Tag.
(DO NOT give out the Serial Number. S/N)
Posted on Aug 01, 2010
No power light on side werepower lead plugs in
I'm sorry, are you certain that your power supply is working? If it is, these laptops are notorious for having power port issues. Your power port module may have loosened from the circuit board, inside the casing where you can't see it. Does your power plug wiggle around a lot after you insert it? If so, you may have to take it to someone who can resolder your port back on the board, or replace it altogether.
Aug 30, 2013 | Compaq Presario Computers & Internet
Hello there.brother i got a laptop pakard bell ms2273 .it shows charging light but not powering on .power button is working
You can try switching off computer, unplug the ac adapter, then the battery. When all powersource are removed, hold the power button. Then put the battery back on then try switching the laptop back on.
Mar 16, 2011 | Computers & Internet
Computer says this drive is not accessible. It has worked fine for two years. It will work on my laptop. I am using Windows Vista
A couple of things here. First, make sure your usb ports are working on your computer. Try plugging the unit into a different usb port. For example, if you usually plug it into the back, try plugging it into the front. If this doesn't work, get a "Powered" usb hub. Your usb ports work on 5volts. Even when they start to fail, they will recognize "non powered" devices like thumb drives or camera cards. Another issue is that the power supply may be failing. Make sure you're using the power supply that came with the drive. If you say it works on your laptop, I'm thinking that your pc's usb port might be failing. A powered hub should resolve this issue. Hope this helps.
Jan 04, 2011 | SimpleTech FS-U25/500E 500 GB USB 2.0 Hard...
Problem with the power supply or battery
This is a simple issue hopefully.
The battery is no longer able to charge.Buy a new one on www.ebay.com ($50-$75)
It could be also that the motherboard cannot charge it (less likely)
sincerely,
Sagacious1
Aug 07, 2009 | Lenovo IdeaPad Y530 Notebook
Brother MFC 210 stops working at start (power supply problem?)
my mfc 210c printer power supply are blast please where to buy power supply circuit
Apr 26, 2009 | Brother MFC 210C All-In-One InkJet Printer
No power
As far as a reset button is concerned you can hold down the power button for a few seconds to turn the power off completely and then power it back up.
If your having power issues and you have a new power adapter thats known working you can try disconnecting the power take out the battery leave for a few seconds then re-insert plug in power and try again.
If this fails try starting just with battery power, if this fails try taking out the battery and attaching just the power adapter and starting up.
Also check that the battery is getting charged there should be a light on the notebook that tells wether its charging.
If this all fails you may have damaged the power adapters connection to the notebook when you bumped it. Hence the battery cannot get recharged to start up.
Let me know how you go.
Mar 23, 2009 | Compaq Presario V4000 Notebook
S Video
Here check out this website it walks you thru it..I don't see why you would have any problems..
http://www.svideo.com/compaq1700.html
Mar 15, 2009 | HP Computers & Internet
Toshiba Satellite M65-S909 laptop will not start
Based on the problem you have described it could be one of many issues as to what is causing the problems. I know that answer doesn't help but need to be up front with you and not list all the possible issues. What I can tell you is that our company would be able to diagosis the problem once at our nationwide repair garage. If your interested in using our company check out our company website at www.LaptopGuy.com. Take a look at the testimonal section to see that we do quality work. I
Jun 01, 2008 | Computers & Internet
Product Key
You should got a reinstallation CD with your purchase.
Try looking on the back of the laptop.
May 02, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Wii wont turn on
unplug from the wall and try it again, if still doesn't try some one else's power supply
Jan 28, 2008 | Nintendo Wii Console
Computers & Internet Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
