Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
15yr old Whirlpool Estate does not stop filling
I just replaced the direct drive coupler on my machine. The spin cycle works. However, when I go to put it into a complete cycle, the washer continues to fill no matter what load-size setting it is on. I've looked at some of the other questions similar to this and was wondering if I have the same problem or something else?
    Problem Solver:
  • 8 Answers
Umm well it is 15 years old so maybe its just ready to go. get a new washer machine.
Posted on Feb 10, 2009
Estate by Whirlpool washing machine Model:etw4400sq0 not spinning.
In my experience, a failed coupling is a likely cause
Dec 26, 2012 | Estate Washing Machines
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My estate washing machine will not spin out, all of the other cycles work correctly.
Hello
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Mar 25, 2011 | Estate Washing Machines
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
Estate washer won't spin
If it still agitates and fills, this is most likely due to a faulty lid switch.
Oct 12, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool gold top load washer (7 months old) won't agitate or spin
It sounds like the motor drive coupler has broken. This means the motor is no longer turning the gearcase, but it is turning the pump. It will be repaired under warranty if it is only 7 months old. You should have a full one year warranty on the washer. If not, he can probably fix it, but it will need a new coupler. He can tilt the machine back and see the coupler between the motor and transmission from underneath. I can walk you through replacing it if you want, but I wouldn't recommend it if it is still under warranty. There could possibly be something more major wrong that has caused it to break and some of the factory servicers are real picky about customers working on a machine under warranty. If you need it running tonight, he may be in trouble.
Post back if you need further help or have more questions.
Thanks/mike
Oct 21, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
89 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
