Question about Creda W100FW Front Load Washer
Where is the filter
I have a creda 1000 ecowash machine. i cannot find the filter. i am told you need to clean it regularly. i havent done it in the 11 years i have it but now it has stopped spinning and i am told it may not necessarily be the brushes.
  • bridget_gibl Feb 10, 2009
    thank you very much. I found the filter and cleaned it as directed. I guess it maybe the brushes after all as there still is not a meg out of the drum. I may be in touch again if I need help with the brushes.
    Thanks again.
  • Creda Master
  • 3,463 Answers
The filter is located at the rear`of the washer.
To access it, remove the rear lower panel.
You will see a large black hose, remove hose from bottom of tub, and you will find the plastic filter inside, remove filter and clean.
Refit filter and hose, and test.
If it still does not spin, then you need to check the brushes.
If you require info on how to check and change them, then let me know.
Please rate my fixya solution.
Thanks.
THanks.
Posted on Feb 10, 2009
We have a creda 1200 spin that bounces round the kitchen when it spins i balanced the feet .its spins fine when empty .please help
Posted on Feb 26, 2009
My creda 1000 shoot water out of drawer when spining.all the water comes up from machine and out the drawer
drain filter plugged? or pump not draining for another reason. Check the filter first.
Jan 21, 2015 | Creda Washing Machines
Water not draining from the drum and no filter in evidence
Remove rear panel of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Aug 15, 2009 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Door won't open at end of cycle Creda 1000 ecowash front loader
Hi Jenny. Do you have the model No. available?
Most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Apr 04, 2009 | Creda W100FW Front Load Washer
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
462 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
sonic boom...
sonic boom...
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
