Question about Panasonic AG-DVC30 Mini DV Digital Camcorder
No elcectrical power
My camera head waqs very dirty ,and while sooting a scene the camera shut down completely .Thereis no elecrical power to the camera when the power switch is turnede on
    Champion:
  • 221 Answers
Most likely problem is a defective power supply board in the camera. parts cost is about $250.00.
Posted on Aug 06, 2009
Getting lines on copys and scans
While on remove power cable from printer wait 2 min, attach power cable again, , or scan glass is dirty
Oct 20, 2014 | HP Officejet Pro 8600
Bd7200 shuts down from loud vibrating scenes
replace player sounds like a bad power supply or ic chip
Jan 21, 2013 | Samsung HT-BD7200 Theater System
Machine showing error D370
when machine waqs working atonce power failure occurred and after that it showed error D370
Oct 26, 2012 | Konica Minolta Bizhub C 353, Bizhub...
My oil fired boiler wont stay fired i cleaned it out it will run for about 30seconds then shut
This can be a result of several things. The most common problem is the photo sensor. If there is a flame, and the photo sensor can't detect it - the furnace will shut down. If the furnace has run dirty and sooty - there's probably black soot covering the sensor, blocking the light of the flame. Remove, wipe the lens, and reassemble. Try for ignition again. Keep in mind, after three unsuccessful starts, the primary control will shut down in lock out mode. This is to prevent an additional start as the chamber is probably soaked with heating oil. It should be cleaned completely before attempting ignition again.
The filter may be sufficiently blocked to prevent fuel to flow at a rate the burner needs. Replacing it may be required. If not a dirty filter, lines may be clogged by bacteria in the oil that has clogged them. You might need to have the lines blown back to the tank with a compressed air tool designed specifically for this purpose. Air in the fuel line can cause the flame to go out, and once out it will not restart without the spark. This can be caused by the constant vibration of the burner. A loose coupling between the blower and oil pump can cause the flame to go out, as could a faulty oil pump. Too little combustion air can cause soot - too much is almost as bad.
The real problem is lack of professional maintenance. An oil burner needs to be tuned, not just cleaned. Proper air / fuel mixtures, nozzles replaced when worn, heat damaged parts replaced, clean heat exchangers, stack temperatures, draft, etc. must all be "tweaked." for optimum performance. A properly tuned traditional burner can be 86% efficient - newer styles well over 90%. But they won't stay that way without annual tuning. With the cost of heating oil, why settle for less than optimum efficiency?
Dec 28, 2010 | Heating & Cooling
When I hit the record button my camera shuts down. The battery is fully charged, there's plenty of memory. It'll stay on while I watch a movie, but when I hit record the screen goes blank and shuts off...
Check and clean the battery contacts as this is sometimes the fault when the camera draws more power and due to dirty or poor contacts on the battery or the camera contacts the camera shuts down due to low power. Hope that works.
Aug 09, 2010 | Cameras
How do you set the self timer on the kodak 10.3 mega pixels
1 In any Still mode, press the button repeatedly to choose: 10 seconds?A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds?A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot?The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later. 2 Compose the scene. 3 Press the Shutter button halfway, then completely down.
Nov 19, 2009 | Kodak EASYSHARE M1063 Digital Camera
Unit Always Shuts Down While In Use
all the laptops on the world have warm problem. if you use your notebook dirty place your fan could get dirty and not working well and not makes cool anymore. in warm system can shut down itself. it is often does. if you open your laptop back case you will see the fan. there are olny 4 screw. clean the fan and screw again. try it.
sorry for my enghlish.
May 17, 2009 | Acer Aspire 7720 Notebook
Using self timer on my digital camera
1 In any Still mode, tap Settings to open the Settings
panel.
2 Tap Self-Timer/Burst repeatedly, until the desired
Self-timer icon appears at the bottom of the LCD:
10 seconds—A picture is taken after a 10-second
2 seconds—A picture is taken after a 2-second
tripod).
2 shot—The first picture is taken after a 10-second
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Apr 29, 2009 | Kodak EasyShare V1073 Digital Camera
Thereis a significant delay between pushing the button and the pi
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Feb 28, 2009 | Olympus FE-240 Digital Camera
Dew Detected message
When the camera's circuits detect condensation on the tape heads, this message is shown and the camera shuts down. This is to prevent damage to tapes, that could stick to the damp head.  It is recommended to leave the camera in a warm and dry place until sufficient time has elapsed for the condensation to evaporate. This may be several hours. Do not leave the camera anywhere too warm that is likely to damage it, like on a stove or radiator.  This issue is commonly caused by moving the camera from the cold outdoors, into the warmth of indoors. If the symptoms persist, the head may be dirty. try a head cleaner cassette, or failing that, return for service.
Dec 11, 2008 | Quasar VM-L459 Camcorder
Panasonic AG-DVC30 Mini DV Digital Camcorder Logo
114 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
