Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE SIDE BY SIDE/MODEL #GSS25JMDCC
Fan in freezer makes a loud noise and behind fridge also. Cooling well.
I also had a loud fan and it was caused by ice build-up on the fan in the back of the freezer. From inside the freezer, I removed the plastic grill that covers the fan (I think I also had to remove the side rails and ice maker) then just let the fan defrost in the sink. Made sure it was nice and dry before putting it back in or else ice would just form again. I also took a sheet of plastic and put it between the ice maker and fan grill to stop water from dripping onto the fan and haven't had a noisy fan since. I just need to remove the ice build-up from on top of the plastic sheet every now and then, but that's much easy than taking everything apart to get to the fan.
Posted on Feb 12, 2009
Fan in freezer side making loud noise
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 17, 2010 | GE HSM25GFTSA Side by Side Refrigerator
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge making loud noises occassionally
the noise can be from the fan next to the compressor or the fan in the freezer.
check them when you hear the noise if they tuch something or they might need to be replace b/c of berring problems...
Jan 06, 2010 | Refrigerators
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
Fridge not cooling and making noise
MY GE ICE MAKER IS MAKING A LOUD NOISE, HOW DO I DISABLE THE UNIT BEFORE IT BURNS UP SOMETHING
Jul 13, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
223 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
