Question about Kenmore Refrigerators
Kenmore C978-66792-1 fridge: defrost ices and stops fan
I can melt the ice around the fan and the fridge works again for about a month. From another site I got the following advice which I will follow but: there is a plug with wires (heavy Orange and White) which are not hooked up and I don't see any place where they can connect into. Are these my problem or just wires for an ice maker model???? I have found the location of the theromstat and timer.
The most common fridge ''not cooling'' problem is a frost free failure... Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat.
    Scholar:
  • 105 Answers
It should just be your ice maker wires and wouldn't be the issue with this fridge
Posted on Feb 10, 2009
  • insteadof Mar 14, 2012
    Hello, what was the final fix? I have the same issue where the water from the pan freezes up on the discharge chute and freezes the fan. I put hot water on the discharge chute and sponge it out. One the ice is gone the water flows freely out the back. Comes back in a month.
My Kenmore elite refrigerator has a error code Er FF what does this mean. thank you
see: http://www.fixya.com/support/t22822607-kenmore_elite_795_72053_112_er_code
Several said unplug to reset "brain" I'd try that first, then the defrost solution. Or possibly a Hair dryer to melt enough of the ice around the stopped fan to allow it to work again.
Mar 04, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
I have a Beko frost free fridge freezer kept in a garage that has all of a sudden just stopped working. I noticed that the bread I'd put in the freezer hadn't frozen and then noticed that the fan had...
If the fan has failed or intermittent, the freezer wont freeze the food properly but usually you get a mountain of ice build up at the back of the freezer. This ice jams and stops the fan from turning. Alternatively, there could be a defrost problem. Unless it is a fully electronic defrost machine, there is usually a little timer on the back of the fridge to force a defrost after a certain time. The fridge will turn off, the defrost heater operates to melt the ice and then usually with 20 to 45 minutes, the defrost timer will "click" back on and start the fridge running again. If the timer is sticking, the fridge may stay on its defrost cycle and never start again, thus, it doesn't get cold. If you find the defrost timer, have a close look for a little shaft or slotted screw type stud sticking out of the middle of it. A slight turn of this and you should hear it clicking around. When you hear a loud click, that is either the start or end of the defrost cycle. If you have a full electronic defrost system, it may be a failed board, heater, thermostat or defrost safety fuse.
Jan 05, 2015 | Refrigerators
Bottom of Kenmore freezer vents icing up. Did test recommended weeks ago, replaced defrost timer. Worked fine for a few weeks and now is back to icing up and fridge not cool at all. Melted ice again with...
If the timer didn't fix your problem, and it sounds like it didn't, then there are 2 other components to a defrost system. The defrost heater, and the defrost thermostat. Both are located around evaporator. Back inside wall of freezer will have to be removed to access these parts. Thermostat will be clipped near top of evaporator coil. Heater will be near bottom of coil.
Sep 15, 2017 | Refrigerators
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
Ice build up around fan in frezeer.makes looud noise....if not melted the refridgrator part a bottom of unit stops cooling.....if melted fan runs smthly....things cool well, but happens again over noght...
The defrost circuit has failed. Typical failures are the defrost heater has opened, the defrost timer if equiped, is not advancing or the defrost thermostat is open. To check the heater, melt the ice, and use a meter to check if the heating elements are open, if they are, then you will need to replace the heating element.
Aug 23, 2010 | Kenmore 64802 Top Freezer Refrigerator
GSH25JFRFWW evaporator fan makes loud deep noise at times
GE refrigerators have a faulty design, and so don't defrost completely, so ice builds up in the evaporator coils and on and in the evap. fan motor. Melting the ice will make the fridge more efficient, and the fan quiet again.
The slow, easy way to fix is take out all the food, unplug the fridge, leave doors open all day. Ice will melt, and all will be fine ... for a few months, until the ice builds up again. The fast way is here.
Nov 15, 2009 | GE Refrigerators
Ice melted and fridge not cold enough kenmore 363.50622000
Several things possible - fan in freezer side not running, defrost thermostat not working, if fan runs and cuts off & on, then the defrost heater strip could be out, but check the defrost timer under fridge; not cycling, you can manually turn to see if fan cuts off and on. If you have "ice shelf" in coils on freezer side then no air circulates in freezer and over into refrigerator side.
Aug 14, 2009 | Kenmore Refrigerators
Temperature not low enough
check fan at the back of refrigerator or you have defrost problem
Apr 05, 2009 | Kenmore Refrigerators
Refrigerators Logo
590 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
