Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
LCD display is blank , won't light up at all?
Checked voltage all good, can anyone help?
  • dddd9esmond Apr 07, 2009
    I have the same problem exactly how much did the circuit board cost ?
  • mikem3636 Apr 24, 2009
    I have a Jenn-Air electric convection wall oven with a similiar problem. Model JJW9627CAB. Can anyone tell me where I can get repair/replacement instructions for my attempt at DYI. Thanks Mike
I had the same problem, mine faded out over time until I couldn't read it anymore. I had to have the circuit board replaced. The technician said that over time voltage surges can burn them out. It used to be frequent that I'd come home and all the clocks needed to be reset, so I know my area does have power problems.
The board comes out rather simply, I'd do it myself if if ever happened again.
Posted on Feb 23, 2009
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
OVen display is blank and oven won't turn on. Oven has power (checked breaker, oven light works)
Can you supply a model number?
Most likley you have a bad erc control board ( clock). But a model number would help narrow it down.
Jan 02, 2011 | Whirlpool RBD275PD Electric Double Oven
The display is blank, yet the light comes on. The
i'm assuming everything works but you cant see the clock?
if this is the case then you need a new clock board.
very common on these wall ovens
Oct 07, 2009 | Whirlpool GBD277PD Electric Double Oven
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
Jenn-Air oven display blank. Only works when oven has heated up.
I had the same problem and just fixed it myself today. Not sure if your timer board is the same but I replaced capacitor C3 35volt 68uf. I also have the dark spot on the clock glass in the corner but it still works. I purchased the cap from digikey.com P10292-ND. I also replaced the cap next to it 35volt 470uf P10301-ND not sure if that was necessary but it smelled a little burnt. The display is normal brighness again - total cost 1/2 hour of my time and $4 parts and shipping. Digi-Key is great I ordered the parts on Thursday 7/23 and got it today 7/25.
Jul 21, 2009 | Jenn-Air Electric Double Oven
I have a Euromaid 1505 TI oven. It worked fine yesterday. Today when i went to use it, the display screen is blank and it won't work. I checked the main power switches in the garage, and everything seems...
I have euromaid 1505TI oven, the bottom element was replaced but since then have been unable to bake cakes, bis, etc without them burning,. have tried lowering the temp but still burns. can anyone help me with this and tell me what the prob might be before i get a tech in.
May 15, 2009 | Ovens
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Display blank
Every time I have seen this problem, it has been a bad display assembly. These are fairly easy to change yourself, but the part is kind of expensive, I think in the $150-$200 range. Hope this helps!
Aug 21, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
391 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
