Question about Canon LaserClass 2060P Plain Paper Fax
Fax is saying "wrong Paper size" ???? please help
Was printing fine, then all of a sudden it says wrong paper size
  • jmeinheil Feb 10, 2009
    Error message Check Paper Size keeps coming up. How do you clear that?
    Fax is saying Check Paper Size. How do you clear that?
    Problem Solver:
  • 6 Answers
PAPER SIZE DETECT ARM IS BAD
Posted on Feb 12, 2009
Shows receive in memory, check paper size
Either the paper size in the fax machine is wrong or there is not enough paper left to print the fax. Add paler and the machine will print the faxes held in memory.
Oct 10, 2014 | Canon Office Equipment & Supplies
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Wont print,keeps saying check paper size
You need to call service, because the flapper of registration sensor is worn out, and fax cant detect right paper size.
Jun 23, 2010 | Canon FAXPHONE L80 Laser
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer will not print, keeps rejecting paper saying it is too narrow. the paper is the correct size. i nee help immediately please
OK there is three places you have to check for correct papersize,-
1)In the settings on the machine
2)On the driver of the printer ,ON your computer -Start,Control panel,Printers and faxes,Right click on driver- Properties,Then you enter the correct paper size.
3)In the page setup in the program you are printing from.File, page setup,set the correct paper size.
Normaly the settings for 1and 2 you enter once and it stays there ,except if some one change it.
Every program have it's own paper size defauld settings.Check them before you print.
Let me Know
Nov 06, 2008 | HP Office Equipment & Supplies
KEEP SHOWING WRONG PAPER SIZE
there is no previous post for your problem please restate.
Are you trying to Rx a fax and it's showing wrong size? do you have a manual? I can give you a link for a free one.
Aug 28, 2008 | Canon FAXPHONE L80 Laser
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax L200 Check paper size problem
This is due to the reg sensor being worn, item 26 in the photo
please order and replace
RB2-1700-030 - LEVER, REGISTRATION SENSOR
hope this helps
Mar 06, 2008 | Canon FAX-L200 Plain Paper Laser
"wrong size paper"
Change the cofiguration of the size in your fax machine see if accepts them then
Aug 16, 2007 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon LaserClass 2060P Plain Paper Fax Logo
230 people viewed this question
old marine
old marine
