Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Optoma EP721 Projector Lamp will not come on
My projector has not been used in several months it is just out of warenty had has not had much use. I tried hooking up my projector after several months and the green power indicator is on then after a few seconds the red lamp and temp indicators come on and stay steady. the lamp never comes on. I do not hear the fan running and am not sure if it is supposed to if the lamp is not lit. I blew out the dust with some compresses air with no luck. Can someone please give me some guidence to fix my unit?
  • 5 Answers
I had the same problem I thought the lamp was Broken orburned out.
I removed the lamp tried  to look at it and see if I could tell if it was burned out or not. Put it back in and it worked.
Oh I forgot! Originally I had loaned it to a friend and it came back broken. The foot at the bottom was broken so I assumed, that it was probably dropped or fell off the table.
So First I bought a second projector because the bulbs were so expensive. Then I did not try to check the bulb for a couple of month's It only had 70 hours on it Anyway Give it a shot. Worked for me
Posted on Feb 27, 2009
Service manual how do i take the cover off of my optoma EP721
Service Manual for Optoma series projectors.
http://easp.optomausa.com/ASP/upload/Optoma%20EP721_EP727_EP723_EP728_EW1610%20Family%20V6.0%20%28DDP2230-USB,%2036.88N03G001%29%20Service%20Manual.pdf
Aug 26, 2014 | Optoma EP721 Projector
I have a Optoma EP721. It now projects verticle lines on the screen background. How do you eliminate the verticle lines ?
It sounds like you have a projector which is in need of professional repair. You should eliminate source material problems first though by checking the projector with alternative input sources, ensuring that you also check the cables, and various inputs on the projector.
If the lines are present on all the inputs then the fault is internal to the projector. This will require professional repair. The first point of contact should be Optoma at www.optoma.co.uk/support.aspx (UK) or http://www.optomausa.com/ (USA). They should be able to give you an idea of ow much it may potentially cost to have your projector repaired and (most importantly) check whether it is under warranty. Most Optoma projectors ship with 3 year warranties these days.
Feb 19, 2011 | Optoma EP721 Projector
Optoma projector overheat issue - fan comes on but switches off
Most projectors have air filters. Yours may need to be removed and cleaned. No air flow = overheat.
May 28, 2009 | Optoma EP721 Projector
Ive had my optoma ep721 projector probably for likle 2 months and
1 of 2 things happened here. Either the power supply is spent or your lamp ballast is busted. In either case it would have to be opened and repaired professionally. may cost upwards of a new projector, so look around for a decent shop and have them test it. If you dont mind me asking, if you decide to get rid of it would you mind selling me the lamp cheaply. Doesnt matter if its burn out, just need the glass from the bulb if its not broken. Hope i helped.
Mar 30, 2009 | Optoma EP721 Projector
Optoma ep721 remote problem
return the projector (still under warranty, if bought new). if it's used, reset the settings on the projector to factory default. if still nothing, replace the remore.
Sep 24, 2008 | Christie 38-VIV211-01 LCD Projector
Optoma EP721 - reverse image
Go to menu, select Projection and choose your desired projection scheme (Desktop, ceiling mounted, behind the screen, etc.)
Jun 03, 2008 | Toshiba TDP S3 Multimedia Projector
723 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
