Question about Yamaha RX-V463 Receiver
Yamaha rx v663 receiver, turntable input
I recently upgraded to a yamaha rx v663 receiver and there is apparently no place to input my marantz 6100 turntable. ios there anything i can do to correct this?
    Scholar:
  • 93 Answers
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
Posted on Feb 11, 2009
How to connect a turntable to Yamaha Rx-v630
If your turn table has a ground wire with the R and L wires then you can not connect it to this receiver. Unless you have a switch on the turn table that chooses between internal or external amp. If you have the switch, pick external amp and then run your R and L into your TV/CD input. Good luck to you.
Jun 06, 2016 | Yamaha RX-V630 Receiver
Yamaha rx-v663 how to set and lock sound program
once you set the audio program for an input, it should stay set even if you power the unit down. As far as locking that program so that it cannot be changed - no there isn't a way to do that.
May 07, 2015 | Yamaha RX-V663 Receiver
I have connected a cordless microphone to RX-V663 but there is no output in speakers? Do I have to make changes to amplifier or select out some outputs?
How did you 'connect' the cordless microphone to the RX-V663? You will need to select this same input in order to get output in the speakers.
Sep 25, 2014 | Yamaha Rx V663 7.2 Channel 665 Watt...
Yamaha rx-v663 is there a firmware update to get hdmi 1.4a support ?
Unfortunatly there is not any firmware to upgrade your unit to a higher HDMI format. There is a firmware though that corrects the following symptoms.
1. In case of playback of some DTS-HD Master Audio stream, pop noise may be generated.
2. Test tone may not be output under specific YPAO condition.
3. When test tone is output from presence channel, surround R channel is simultaneously output when speaker settings are PRESENCE SP "EXIST" and SWFR "NONE".
4. Multi channel input setting will be reset after power off the unit, in case of setting "INPUT CH" to "8CH" and "FRONT" to "VCR" or "V-AUX".
Apr 10, 2012 | Yamaha RX-V663 Receiver
Can the Yamaha RX-V663 (7.1) be upgraded to handle 3-D video input?
Long story short... No. Use your 663 for digital audio, Run video direct to TV for BLURAY & or Cable for 3d content. You can still switch all other video sources thru the receiver. Not cost effective. cost more to do it than you paid for it. Hope this helps
Jul 10, 2011 | Yamaha RX-V663 Receiver
I have a Yamaha RX-V663. I recently upgraded to 7.1, but the 6th and 7th speakers do not activate on DTS HD Master Audio Blu rays. The 6th and 7th speakers do activate on DTS True HD, DTS EX - ES,...
It is unclear to me as to what you mean when you say they do not activate. Does that mean that they just don't play, or does it mean that your receiver doesn't show them on the display? If your not hearing the sound from the speakers, are you sure your dvd movie is capable of outputting 7.1 or is it only 5.1?
If the receiver doesn't show the speakers on the display, try running through the speaker setup again to make sure you selected both sides and rears for the setup.
Good Luck
Jan 06, 2011 | Yamaha RX-V663 Receiver
Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Jan 28, 2010 | Yamaha RX-V663 Receiver
Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Jan 16, 2009 | Yamaha RX-V463 Receiver
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
Jan 07, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V463 Receiver Logo
618 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
