Question about LG DLE2515S Gas Dryer
We have a 2006 LG Model DLE5977W that is making a clunking noise when it runs. We tried it with different size loads, as well as with no load in it at all. It seems to dry ok but we're nervous this might become something worse. Please Help! I have the same problem, cracked drum 2 yrs. 4 months old. What is the cost of the part??? I can only imagine what the labor would be....I heard very costly????
  • jpulickal Feb 19, 2009
    We bought dryer DLE5977 approximately two and a half years ago; started making the noise after two years and is now very loud.
  • 5 Answers
Clunking could be from bad rollers or cracked drum. Check the drum seam for a crack. If its the rollers you can do the same thing as drum replacement only order the rollers. I got my parts from Sears parts. The below is for a 2514 but should be close for yours.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Posted on Apr 02, 2009
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
Dryer making a louder than normal noise when drying
Possibly the roller, I would have to hear it to be sure, but if it sounds like a clunking noise, it is probably a roller, if it is more of a high pitched whine, or a sound like a penny in a vaccum you probably have something stuck in your blower.
Dec 18, 2009 | LG DLE5932S Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer Making Lound Wobbling Noise
I'll bet the drum is cracked.
Jan 11, 2009 | Dryers
Washer makes clunking noises.......
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
Oct 16, 2008 | LG DLE5977 Electric Dryer
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
What kind of noise was it making. Squeaking? Clanking/clunking? Jet engine loud?
Nov 13, 2006 | Zanussi WJS1397W Front Load Washer / Dryer
LG DLE2515S Gas Dryer Logo
2,058 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
