Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Does the machine heat up the water
We only have a cold feed but the washing machine does not heat up the water model no lsq8000
  • 1 more comment
  • scotchpaddy Feb 12, 2009
    thanks for your reply
  • Anonymous Mar 15, 2014
    lg washing machine model F1256QD The water does not heat up
    LG Washing machine model f1256qd the water does not heat up
  • 10,865 Answers
If you have only a cold water feed then all of the washing will be in cold water. Dishwashers heat up the water, but clothes washers do not.
Posted on Feb 12, 2009
  • Joe Hogan Feb 12, 2009
    Oops, the answer above is not correct if your machine was made for the Unkted Kingdom market.
I have no hot water as heating element waiting for repairs.Ia it ok to use washing machine with just cold water
Yes its fine. Most washers only have a cold feed anyway. But if yours as hot and cold the washer will heat it up
Mar 25, 2017 | Washing Machines
There is nothing to indicate that the machine heats the water. We thought by connecting the y piece and just using cold, it would only be cold water. .
Most new washing machines only require a cold water feed! You should only connect the cold water feed and leave the hot water feed disconnected and turned off at the valve.
Mar 19, 2016 | Washing Machines
Hose attached to cold tap will water still heat up
The washing machine does not heat the water, you must pre-heat it and feed it by the hot water inlet.
May 30, 2014 | Indesit W 83
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
In a previous house, we had both a hot water feed and a cold water feed. My new house only has cold water feed, can i still use this washing machine?
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end screws into the cold water supply and the hot and cold washer pipes screw into the double end. The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Good luck,
John C
Mar 16, 2011 | Indesit W 123 Front Load Washer
Does the wma76 hotpoint need a hot water feed? Is a cold water feed enough?
Hi from retired Englishman in France (it's 21:29!),
If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
Hope this answers your question.
John C
Jan 26, 2011 | Hotpoint WMA76 Front Load Washer
Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Apr 11, 2009 | Bosch Washing Machines
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
192 people viewed this question
Dan Webster
Dan Webster
Sal De
