Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Will not open
My 1tb external is only two months old and will not open, it recognizes it on vista; says that driver is installed successfully; but never goes beyond that. When I try to open through "computer" ; explorer stops responding. Any ideas ?
  • 3 more comments
  • sicklittle1 Mar 17, 2009
    I have the same issue with XP Pro.
    Has been working for months and now it wont.
    Any help would be awsome. It is a 12 year backup of customer files for my work.
  • jenn12345 Apr 16, 2009
    what if the hard drive didn't come with a cd
  • ayanes Apr 16, 2009
    I have the same problem the system says PnPDriverNotFound, and this is the answer from WD Have you performed the latest Windows/Macintosh updates as well as updated all the device drivers on your computer? Have you tried connecting your external hard drive's USB/FireWire cable into a different port on your computer? When connected to a different port, do you have the same problem? Have you tried a different USB/FireWire cable? Are you experiencing any other problems with USB/FireWire devices on your computer? Have you tried the external hard drive on a different computer and does it have the same problems?
    I still can´t reinstall the hard drive......
    this hard drive doesn't have a CD installer
  • pitjaga Apr 19, 2009
    My 1tb external will not open, it recognizes it on xp; says that driver is installed successfully; but never goes beyond that. When I try to open through "computer" ; explorer stops responding. Any ideas ?
  • TERRY0404 May 03, 2009
    Western Digital My Book Essential 1TB External USB 2.0 Hard Drive - every time I plug it in I get a message that the driver failed to instal properly, then I can open the drive directory but if I try to open a folder, it stops responding. Same happens on completely different notebook one with Vista, one with XP.
  • 36 Answers
Try to install the cd that comes with the hard drive. Vista was installing generic drivers that might not work with your drive.
Posted on Feb 14, 2009
How can I install the driver for My Passport WD External HDD 500GB online?
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
Nov 11, 2010 | Western Digital My Passport Essential SE...
I can't get Vista Ultimate set up to recognize my WD 1TB HDD in a new build. Is this a software problem or problem with the HDD. I get the short beep at BIOS start up so I don't think its with the...
Few steps to check your harddisk status on the motherboard would resolve this issue. Checkin to the cmos setup and look for the detection of the HDD and the size it shows once you have done a formating.
Vista 64 bit shows issues at times while installing a new SATA 1TB HDD. Check if the 1TB HDD is installed on to SATA 0.
Use a WD Disk Manager and format the HDD initially and then try install Vista on to it. Else if this doesnt work on the system, Put the HD on to another working system and Format it with NTFS File system and try installing Vista.. You will be successful. Good Luck.
Feb 13, 2010 | Gigabyte GA-MA785GPMT-UD2H AM3 AMD 785G...
1tb Drive flashes, but will not be recognized by computer. Tried on both XP and Vista machines. Not seen by either. Is there any way to remove drive and place inside Vista box?
yes if your system has supports sata drives.
just take out of the case and install in your system.
make sure you have a sata cable.
Have you tried esata there is a cable that plugs into the mother board and goes into a pci blank slot that gives you esata this is the easest way to go
Jan 10, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital 1TB harddrive won't open on laptop, will on deskt
Hi Helen,
You almost have it. Format it on the laptop, and the 64bit desktop will be able to read it.
Good Luck,
don't forget to leave a rating.
Thanks
Mark
Sep 17, 2009 | Western Digital MY BOOK HOME 1TB EXT...
1TB Verbatim external hardrive not recognized
Try taking the drive out of the enclosure and buying a usb adaoter that will fir the interface the hard drive has...either EIDE or SATA, then hook that up to a usb port and see if the computer will load it. May be the controller card in the enclosure is your problem.
Sep 02, 2009 | Verbatim VER95327 USB Hard Drive
I have a simpletech 1TB ext. hard drive BOM No.
You need to install the hard drive driver for the PC to recognize it. If you don't have one, just look in the internet for a free driver.
Regards,
Jeep Brainy
Aug 14, 2009 | SimpleTech 1TB SimpleDrive Pro External...
My Western digital 1tb wont work inspite of drivers being instal
Mybook does not require any additional driver to work on systems from Win XP onward, same for recents Linux and MAC OS.
If the drive is not detected on more of one computer, then it is usually because of a fault.
Try a replacement cable (mybook uses Mini USB to USB, available at computer and at camera shops). If still no luck contact WD, mybooks have one year warranty. If you want to recover data, the disk must be mounted on a different enclosure, that service can be asked when discussing repair.
Regards
Jul 12, 2009 | Western Digital My Book Essential 1TB...
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
Jan 12, 2009 | Western Digital WD2500JS 250GB SATA2...
Computer wont recognize external drive
The simpletech 1tb drive's case has issues. I had the same problem. It actually quit while I was running a video off the drive. I replaced the case by removing the harddrive from the one it came in and installing it in another case and now it works again.
The first thing I would try is installing the drivers it came with, but failing that you will need to replace it's case.
It has 4 screws to remove, 2 under the silver warranty voiding tape and 2 visable on the bottom side. Remove them, then use a flat screwdrive to pop the case open (gently). Then remove the harddrive.
You will need a case with SATA data AND power cables for this to work.
Sep 26, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
607 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
