Question about Canon CLC 5000 Copier
How to print envelopes on clc 5000
I cant get envelopes to feed from stack bypass. Is there a setting or software that should be installed to print envelopes?
    Problem Solver:
  • 19 Answers
This not necessary a software because this machine have got that funcion on setting to bypass and casset
Posted on Feb 10, 2009
I want to print envelops on my office canon imagerunner 5570. i cant? help.
use the stack bypass for envelope printing.there u can choose the paper size as envelope depending on the size and also u can set ur own XY size for the envelope
Jun 03, 2011 | Canon imageRUNNER 5570 Copier
I need to print standard size 10 envelopes. Where/How do I load them? WorkCentre7335
Some setup will be necessary both on the WorkCenter and in your software. I will describe these steps and leave you with a link to Xerox to check as a reference:
On the WorkCenter 7335
1) In the Bypass tray, load the std. 10 envelopes width-wise with the side to be printed down, flaps tucked in and with flaps entering the printer first. Slide the guide to just touch the edges.
2) Touch <Change Settings> on the WC 7335 screen
3) Select "Envelope" from the "Paper Type" list
4) Select "No. 10 Env" from the "Paper Size" list
5) Select "Save"
6) Select "Confirm"
In your software:
As you did not specify your software, it is important to note that whatever application you are using, the following settings must agree with the steps above:
1) Feed method = Face down, Clockwise rotation
2) Feed from = Bypass
These options may be chosen in different ways depending on your software program.
You may review these setup steps for Word here:
Xerox WC 7335 Print Size 10 Envelope
Jan 25, 2010 | Xerox WorkCentre M118 Laser Printer
My Imagistics Model im2520f won't print envelopes
Printable envelope
[ Manual-related ] Field Remedy There are 7 kinds of envelopes printable:
Yougata 2 (114mmx162mm), Yougata 4 (105mmx235mm), COM10 (4 1/8x9 1/2inch), Monarch (3 7/8x7 1/2inch), DL (110mmx220mm), ISO-C5 (162mmx229mm) and ISO-B5 (176mmx250mm)
For important points when loading envelopes on the tray, refer to Reference Guide, Making Prints Using the Stack Bypass in Chapter 1 Before You Start Using This Machine.good luck mate,pls rate me!!!!!
Sep 18, 2009 | Office Equipment & Supplies
Envelope printing
I have an older, but similar, 5510 model with the same problem. A partial solution that works about 75% of the time is to tuck the envelope flap inside the envelope and give the end of the envelope that is to feed into the machine a slight curve by gentlly bending it on both sides. Then make sure there are only a few sheets of paper in the paper tray (less than 1/8" thick stack). Position the envelope so it is only about 1/2" from the end of the paper in the tray so the feed rollers have to transport it into the machine. I also have to set the margin for the return address in Word to be 1" from the edge of the paper so it prints in proper position, but this may be a problem with my Word 2000.
Feb 07, 2009 | HP Officejet 6310 All-In-One InkJet...
How to Print an Envelope
User manual should have been installed with the software that runs the printer from your computer. My WindowsXP system has a main menu item for the printer. Mine says "Xerox Phaser 3124", but it's really the same as the Samsung 2510.
When you go to print, select the printer, then the type of paper (envelope). This can be done by going to printer properties and then the layout and paper pages. You will want to insert the envelope just above the stack of regular paper, in the single sheet feed area.
Feb 05, 2009 | Samsung ML-2510 Laser Printer
Xerox Doc 12
should be ok if you use the bypass
Jul 31, 2008 | Xerox DocuColor 12 Color Copier
Put envelope in bypass tray. Print on it.
Jul 23, 2008 | Brother Office Equipment & Supplies
Printing envelopes
Dear all,
Im interested this model canon IR-2800/ 2200 /3300 /7200 /8500 /105 /6800 /6000 /5000 /600 /400 / 6020 /5000i /G.P 605/405/ CLC 1140/1180/1120/1100/1150 please kindly quotes us...Here my email add. mapedz_toquero@yahoo.com
May 22, 2008 | Canon imageRUNNER 4570 Copier
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Paper / Envelope feed
Envelopes Follow the steps below to load envelopes into this product. Lower the output tray and slide out the extension. Move the feeder guard towards you. While holding down its locking tab, slide the left edge guide so that the distance between the two edge guides is slightly wider than the width of your envelopes. Load envelopes short edge first with the flap side down, as shown in the illustration. Use the line on the feeder guard as the indicator when loading envelope. The right edge of envelope is aligned with the line on the feeder guard. Set the feeder guard back. Note: * The folding quality and thickness of envelopes vary widely. If the total thickness of the stack of envelopes exceeds 10 mm, press each envelope in the stack flat before loading. If print quality declines when a stack of envelopes is loaded, load one envelope at a time. * Do not use envelopes that are curled or folded. * Flatten the envelope flaps before loading. * Avoid using envelopes that are too thin as they may curl during printing. Extract from CX3200 user manual
Sep 25, 2006 | Epson Stylus CX3200 All-In-One InkJet...
93 people viewed this question
old marine
old marine
