Question about Dell Dimension 4600 PC Desktop
Blue screen with error message
I have a blue screen with an error on it
  • dirinda89
    dirinda89 May 11, 2010
    What does the error message say?
  • Dan rogers
    Dan rogers May 11, 2010
    What does the error say? There should be some string of numbers or some error code
    Scholar:
  • 67 Answers
It is also called BSOD or blue screen of death ..it could occur because of recent hardware change, faulty hardware. Please restart your computer if that occurs again ..try to remove hardware one by one or just operate your computer with minimum accessories first and then add it later on whichever is comfortable to you. If that does' t work then it might be your harddisk too ..u might need to replace your harddisk.
Posted on Feb 10, 2009
Blue screen unable to restart windows10
A stop error (also called a "blue screen" error) can occur if a problem causes your PC to shut down or restart unexpectedly. When you experience this type of error, you won't be able to see things like the Start menu or the taskbar on the screen when your PC is turned on. Instead you might see a blue screen with a message that your PC ran into a problem and needs to restart.
If you see a stop error while you are upgrading to Windows 10, setup will automatically go back to your previous version of Windows.
If the error continues, try to fix it by removing software or hardware.
Sep 22, 2017 | Blue Computers & Internet
Hp Presario 2000 will not get to windows sign in
Do you see an error message on the screen or, does it blue screen with an error message? When you boot up press F6 just as the PC drops out of BIOS mode. Select "Last Known Good Configuration". If that doesn't fix it, look up the error code on the blue screen with Google. Most blue screens are fixable. Some require a complete rebuild of your hard drive.
Aug 25, 2013 | Fujitsu LifeBook S6510 Notebook
Mitsubishi wd 52628 input issue, blue screen and input error
there are no analog channels, they are all digital now, be sure your antenna is facing proper direction before scanning for digital channels
Apr 20, 2013 | Mitsubishi WD-52628 52" Projection HDTV
Error code OFOO:O75D error:OFOO:O244
Is this from a blue screen error ?
A "STOP" MESSAGE in white letters behind a blue background?
If it's a sata message (hard drive error message), this means that your harddrive is dead or about to die. Most likely its already dead, this error means also that the harddrive cant be read anymore.
Mar 05, 2010 | Dell Inspiron 1501 Notebook
Customer get blue screen
Windows blue screen errors are mostly hardware or driver related. Check the exact error message on the BSOD screen and also check the event log to see the error details.
Based on that info you can find the solution.
Here is how to analyze and solve blue screen errors.
Oct 20, 2009 | Compaq Presario 2200 (292600-004) PC...
Why my laptop always blue screen after play games
try to reinstall the videocard drivers or your laptop is not recommend for gaming or replace memory card
Aug 16, 2009 | ASUS LGA775 SOCKET FOR INTEL CORE2...
Blue screen
hi is this blue screen is always be previewed when u turn on ur laptop or it appears when ur laptop boot
if this happens when ur laptop boot to ur windows then ur screen will show a blue screen with errors code that show there is a problem with ur pc and this happens to prevent a harmful to ur laptop
so if this a problem write me the overall error message or take a picture of ur laptop when it shows this error message with blue screen and send it to me here or via mail to ghassanalasmar@hotmail.com which is appeared in ur screen with blue screen to tell u how to fix it
Aug 09, 2009 | Toshiba Qosmio G15-AV501 Notebook
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
Error is occured.
Blue sreen problem occurs either faulure of Hardware or software and solution is right the message which is displayed on blue screen so you need to look at message once and follow the procedure according to blue screen.
if you are not aware of it then please post back the message which appears on blue screen.
and vote all answeres.
Mar 04, 2009 | Microsoft Windows 98 for PC
Crash and blue screen with error message
You would first need to make sure Windows does not restart automatically when a blue screen error appears. Then you can analyze the problem and fix the cause.
Have a look at BSDO error fixing.
Feb 22, 2009 | Samsung NC10-14GW Notebook
Dell Dimension 4600 PC Desktop Logo
81 people viewed this question
Alun Cox
