Question about Canon imageRUNNER 5570 Copier
Canon ir 5570
Ok, I just change the primary charge unit,now we can just see the copy well but we can see black lines parrallel and perpendicular, and the copy not all blank pages the copy is defects.
and a Err code EOO61-000
  • henrique quiteculo
    henrique quiteculo Feb 11, 2009
    this err refer to image formation, do you have to removing the primary fan duct.a and do you have to see continuity check of harness
    henrique quiteculo Apr 09, 2009
    ok I just do and the machine work good tanks but I need to remove the potential sensor assembly ok
    Sergeant:
  • 199 Answers
Replace carona wires or change primary charge unit
Posted on Feb 15, 2009
  • Sunil Rathod Apr 09, 2009
    you also done without removing the potential asmbly. just off the potential control mode in the option menu (SETUP MENU)
  • Sunil Rathod May 22, 2009
    please rate
Canon ir 6570 e 000824-0001
This is the error indicating that the Primary Charging cooling fan is either not plugged in or is not working. Check the connection. I've never had to replace a fan yet. This connection is the one attached to the cooling duct that has to be removed to get to the primary corona assembly. Good Luck.
Sep 12, 2011 | Canon imageRUNNER 5570 Copier
How dum unit works ? There is black lines appear on copy
if the black line is in the direction of paper travelling, change the dc blade or check heater roller .if the line is vertical there may be problem either with drum or primary charging roller. replace the drum first if problem do not disappear replace primary charging roller above the drum.
Jan 04, 2011 | Canon imageRUNNER 400S Copier
6570 - e804-0001
E824 There is a primary charging cooling fan error.
0001 The primary charging cooling fan stop signal has
been detected for 5 sec or more even when the
primary charging cooling fan is on.
Service manual says:
- Check the connection of the connector.
- Replace the fan.
Why did you changed power supply? Did you try with new dc controller?
Jun 29, 2010 | Canon imageRUNNER 5570 Copier
My ir 400 gives a white spot
something could be blocking the primary chargeing corona wires/roller. i see it a lot on the ir 5000 when the primary corona assmbly cleaning pads get stuck half way through the cleaning cycle.
Jun 16, 2010 | Canon imageRUNNER 400S Copier
Intermittent E0061-0001 on a IR6570 canon
Have you tried to replace the Primary Charge corona unit? How about the rear block for the primary? Try to blow it out.... I did see in the book to try to run DPC in service mode... I also remember on older Canons that some times the wire ties may cause a problem... Also, you say that you are getting background... Is the laser good? Come to think of it I had a IR-5000 do the same thing and it turned out to be the rear corona block for the primary & transfer corona units... Good Luck
Mar 01, 2009 | Canon imageRUNNER 5570 Copier
Err E0064-000
There is a problem with the Primary charge unit. You may have a broken corona wire or the grid is arching out. Unless you are a service person, I can help you. If you are not you may have to call for a service rep. The problem can not be reset till the problem is resolved. Sorry, wish I was more help
Feb 07, 2009 | Canon imageRUNNER 5570 Copier
No copy quality in my ir400
to improove copy quality
1: clan the cd unit & use fresh toner
2: clean the primary & transfer charging rollors
Nov 25, 2008 | Canon MF8180C Color Laser MFC Printer
E O61-02
Pull out the primary corona. Clean it good and change the primary wire. If you still get the code, you might want to try another primary corona unit.
Aug 12, 2008 | Canon imageRUNNER 5570 Copier
Canon ir 8500
E010 relates to a main motor fault. A specified amount of rotations has not occurred within a set time. Check motor, see if it turns by hand. If not, inspect and/or replace. Check belts and gears for wear/damage, replace as necessary. E065 relates to a primary charging problem. Suspect primary corona arcing, corona wire broken, High-Voltage PSU may be unservicable, black developer unit may be pulling HVT down. How many copies has each machine done? Recommend calling an engineer, parts are probably required.
Sep 09, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 5570 Copier Logo
245 people viewed this question
old marine
old marine
Corne Viljoen
