Question about Epson Stylus CX3810 All-In-One InkJet Printer
Black and white not printing correctly, color is fine
I have an Epson Stylus 3810. It's been working fine until recently. When printing a document without color there appears to be gaps in the output. Some of the document prints fine, some does not. If I print the document from Word and change the color from black to blue, the document prints fine. I've ran the nozzle clean utility several times and gone through a bunch of ink. Any suggestions on what I can do. The Epson support page suggested I leave the printer off for a day or so so any hardened ink will soften. I replaced the black ink cartridge with a third party ink product first, then thinking that was the issue replaced that with an Epson black ink cartridge. The result is the same. Any hints or tips are greatly appreciated.
  • Anonymous Mar 12, 2009
    Is there a specific process to cleaning the ink tubes? I read on a webpage a process to clean them. I've used third party cartridges in the past. This particular webpage suggested that the ink dries up and becomes hard on it's way to the head. Sorry if I am not using all the correct terms. This printer has been working great until recently. Thanks for your help. It's greatly appreciated.
  • WandaE Apr 24, 2009
    I only use Epson ink cartridges and have issues with the color ink not printing correctly. There are lines throughout the images. I often have to run the nozzle cleaning system several times to get this to stop and that is a huge waste of ink. I got tired of messing with this. I just bought a different printer and am getting rid of this one. Not worth the hassle.
  • 3 Answers
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Posted on Mar 12, 2009
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Cannot print in black and white. Where is the
open your document which you want to print .. give print then select your printer ...>go to printing preference then go to color tab ..>there you can find option called print color in gray scale ...>select the option and check ....
Jan 05, 2010 | Epson Stylus C40UX InkJet Printer
My printer wont print black and white only
My Epson Stylus cx8400 uses ink so fast. I would like to turn this into a black and white printer only. The problem is, I am out of one of the color ink cartridges and it won't let me proceed until I replace it. Is there a way, in the mode it's in now, to get this to print with the black and white only? I am nearly out of ink on all color cartridges now and do not want to purchase more at the high cost they are.
Thank you!
Oct 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HOW TO TAKE PHOTOCOPY IN EPSON STYLUS CX 2800
place the document in side, by the left hand top you will see copy, with two different buttons one is coloured and the other, click on the coloured to get coloured document and click on the black to give you black and white, just once and make sure there is paper in the feeder, thanks
Jul 13, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
MacBook Pro Epson Print Driver Dilemma
your problem is about profiles. The gutenprint is the only way to print from intel to r1800, but this driver don't use the same ICC profiles. You have to use one of three solutions below:
1 the best, you have a profile calibrating device, you make a profile of your couple ink-paper and you convert your document into this ICC profile.
2 you convert your picture into your software in one of the Epson generic profiles (hey probably still are on your computer) and you print whithout color managment
3 (awful) you anticipate the color distorsion and you tune your picture to be bad on the screen but pretty good on paper.
Feb 03, 2009 | Epson Stylus Photo R1800 InkJet Printer
Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
My printer prints mostly all green
try to run a head cleaning cycle: are you on a mac or windows/ go to utility or maintenance and run head cleaning cycle
Mar 28, 2008 | Epson Stylus C86 InkJet Printer
Epson stylus photo r220
Open the printer Properties, Under quality there should be a box
that you can check (print in greyscale) or (print in black & white).
You have to remembe to uncheck to print in color.
Feb 04, 2008 | Epson Stylus R220 Photo Printer Color...
Open Questions:
See all Epson Stylus CX3810 All-In-One InkJet Printer Questions
Epson Stylus CX3810 All-In-One InkJet Printer Logo
415 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
