Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer MAH3000AWW seems to backfill after cycle
Maytag Neptune washer MAH3000AWW, S/N 25130927:
After washing cycle is fully complete, at first NO water is visible in drum, but it becomes visible over time with no further use e.g. wash complete 9am one day. Checked frequently except late evening and overnight. When next checked at 10:30 next morning 0.25" had accumulated. I can hear no dripping sound when the machine is off.
When I turn the dial to just after the spin sign, and let it run through the rest, the water is drained away. The other day when lots had accumulated, I had to do this twice to get rid of it completely (I probably had turned the dial too far around the first time).
The DOOR LOCKED light is on throughout the wash cycle.
The spin cycle seems to work fine.
When we first bought the machine, we used HE powder and no conditioner. Later we switched to liquid wash and no conditioner, and then to liquid wash and conditioner. After a couple of years of the switch to liquid wash, we noticed the terrible smell everyone else has complained off. I bleached regularly, but it always came back. After one final bleach, I switched back to powder and white vinegar instead of conditioner. I have been smell free since - so I assume I have minimal gunk accumulated.
In the past (months and months ago) we have had the very odd occasion when clothes did not seem to be as spun dry as they should be. I mention this in case it is related.
I am currently in the middle of a timed test where I have turned the water off at the faucet to rule out a faucet leak, but I seriously doubt that is the problem.
I would really appreciate any advice.
Thank you
  • bishop_m Feb 10, 2009
    Further to my posting:I should add that when the mold and other major issues first came to light with Maytag, we had the fixes done (by the Maytag repair man) e.g. new boot, wax motor, control board.
    MB
  • bishop_m Feb 12, 2009
    Update to posting: There was no water accumulation in the tub over the same length of time with the faucet switched off. Does something need cleaning - if so what and how do I get to it? Or does something need replacing - if so what and how do I get to it? I do have access to a manual. Thx MB
    Scholar:
  • 79 Answers
It could be a leaking water valve. The MAH3000 has two flavors, the earlier model had (2) extra wax motors in the soap dispenser for the bleach and softener controls and the newer ones have the bleach and softener valves integrated into the water valve assembly.
Contact me via the www.neptunehelp.com site and let me know which serial number you have and I can detemrine which water valve you will need.
See www.neptunehelpsong.com for a funny new song dedicated to Maytag Neptune owners explaining the door latch wax motor issue.
Posted on Feb 13, 2009
2 Suggested Answers
EllaWatson25
  • 725 Answers
SOURCE: Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Posted on Oct 01, 2009
Maytag Neptune Tripping circuit breaker midcycle
this looks like it may be your wash heater or your motor
if you take off your motor lead from motor if it still trips ???????? then look at the heater it wants to be replaced
Nov 22, 2013 | Maytag Neptune Washer Door Mah3000aww
Neptune washer mah3000aww skips to spin cycle and wont drain
It sounds like the "repaired" main control board is still the issue with it being intermittent.
Nov 20, 2012 | Maytag Neptune Washer
My maytag neptune MAH3000aww washing won't go into
most common issue with these is the door lock assy. You need to remove the control panel and check the R11 resistor on the board most likely it will be burnt. This was a common issue a few years back. If the R11 resistor is burnt you need to replace the door lock AND control board or your problem will occur again.
Hope this helps _MJ_
Jan 31, 2010 | Maytag Washing Machines
I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Jan 25, 2010 | Maytag Washing Machines
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Maytag neptune washer MAH3000AWW
order the wax motor kit and replace parts from the internet. there are plenty of videos how to do this. it does require minor soldering and a little mechanical aptittude.
Dec 30, 2008 | Maytag Neptune Washer
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Nov 20, 2008 | Maytag Neptune Washer
MAH3000AWW Trips 20Amp Breaker at rinse cycle
The motor is known to have bad windings. Do a search for "Neptune Washer will not start" Also just inside the control panel where the start/stop sw is should be a paper folded with the diagnostics test and schematic. It is tucked under the pressure sw attached to the back. If not there then search "Maytag Neptune motor phase test" There is also a Service Manual FREE at Goetlieh's site.
Sep 27, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
614 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
