Question about Baumatic F60 Stainless Steel Kitchen Hood
Where do I put the charcoal filter?
I have a new CDA cooker hood which eventually will be extracted outside, for the moment I want to use it as a recirculating one but have been told I need a charcoal filter, where would I need to put this as there aren't any instructions?
    Scholar:
  • 105 Answers
It would fit over / into where the other filter goes the charcoal filter is to help eliminate more smoke and grease
Posted on Feb 10, 2009
How to replace charcoal filter on Electrolux cooker hood
Hey Peter, thank you for your inquiry!
Based off the information you have provided you need help replacing the charcoal filter inside of your Electrolux range hood. I would be happy to help assist you further in order to do so I would need to have your model number. You can locate the model number of the inside of your range hood. Once I have that information I would be happy to help you further. -Matt
Mar 01, 2016 | Electrolux Washing Machines
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
Charcoal filter for cda cooker hood only number i have is TYPE IN1KB1BS Ref INT/CIN installed nov.2005
I had the same problem. No information in the user manual or on the internet about what filter to use. But actually, its not a problem at all because the filter is a universal one! B&Q sell 3 or 4 universal filters, the important thing is to choose the one that has the same diameter and the same central fitting. The one you need is made by Designair and says on the label "suitable for models VH60S, VH60W, IH60SS. It only costs £4.95.
Mar 10, 2010 | CDA PISCES CPP9 Kitchen Hood
Hi. How can I tell if the charcoal filters in my Smeg cooker hood need replacing? They cost £80 so I don't want to replace them unecessarily.
Firstly operate extractor normally,hold a piece of A4 paper on the underside of fan and see how it holds it on the different speeds.Then if you can remove the charcoal filters then operate as before and compare the difference between the suction,this should tell you if it is the charcoal filters or a blockage in the pipe.
Hope this helps
Jan 25, 2010 | Kitchen Ranges
How to fit a designair extracter cooker hood ,charcoal filter
As for all of us as Experts at Fixya. We would greatly appreciate if you would place your question in the right category so that an Expert with knowledge of this field can provide you with help. Sorry that I could not be of more assistants. I will inform other experts in this field of your issues so that they can redirect to help you. Thank you for using Fixya.~WEBMASTER21
Dec 02, 2009 | Facebook Computers & Internet
How do you replace the charcoal filter in a Homark cooker hood (model no. 02 500560)? The whole filter spins round a short way but doesn't drop out.
Try giving it a slight pull as grease sometimes acumulates and stops it from dropping past the lugs that hold it in place.
Oct 05, 2009 | Kitchen Ranges
Cleaning or replacing filter in a cooker hood
Charcoal filters should be replaced.
Apr 10, 2009 | Kitchen Ranges
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Charcoal filter for rangehood
The charcoal filter is for if you do not have the hood vent to the outside of the house. The charcoal filter does not come with the hood you need to buy it separately and It will tell you where to put in the instructions that come with it.
Good Luck And Please Rate FixYa!
Dec 27, 2008 | Franke Kitchen Ranges
Neff cooker hood
the manual i have says that the charcoal filters inside need changing about every 6 months. take out the grease filters then you should be able to turn it and take them out. you may not have these if the extractor vents to the outside. the grease filters can be cleaned with a neutral detergent and then put back in. Make sure the electric is off before you do any of this. Hope this makes sense and helps!
Jul 09, 2008 | Kitchen Ranges
Baumatic F60 Stainless Steel Kitchen Hood Logo
541 people viewed this question
Top Baumatic Kitchen Ranges Experts
ray gallant
Jay Plesset
Todd B
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
