Question about Amana Heating & Cooling
Frost buildup This is a new unit. There is some frost build up on the coils, is this normal or is there something wrong. This when it is used in heat mode.
    Scholar:
  • 144 Answers
You have a heat pump. It is absolutely normal. Every so often the system will go in to defrost mode where the system actually changes in to cooling so that the outdoor coil will be warm enough to melt the frost. At this time the fan outside will not be running, just the compressor. You may also see some steam coming off of the unit. Don't worry, that is normal too. It's not smoking. Please let me know if this info. was helpful and give me a fixya rating.
Posted on Feb 11, 2009
In middle of night, heat pump makes noise like something comes on and builds up then cuts off with a humming sound over and over again. Temp outside was only 43 degrees F.
The unit is defrosting. This is normal for heat pump systems, and they do it worst when the outdoor temperature is between just below freezing up to about 45 degrees F. The more humid it is outside, the more frost builds up, and the more the outdoor unit will defrost. Below about 25 degrees, most of the water is on the ground (not in the air), so the units will not have to defrost as often when it is that cold outside. If you are curious, you can monitor the unit on a cool, foggy day to see if it is actually building up frost, or if the unit is set wrong and defrosting on a false alarm. IF THE UNIT DOESN'T LOOK VISIBLY FROSTY, IT HAS BEEN SET TO DEFROST TOO OFTEN AND IS WASTING ENERGY! A TECH CALL TO REMEDY THE UNNECESSARY CYCLING WILL PAY FOR ITSELF QUICKLY!
While the outdoor unit is in this mode, it should be steaming and making a buzzing noise. This verifies the frost is being boiled off of the outdoor coil. 25355479-u40lsvyytnuesyuv3fbafhtd-5-0.jpg
Please mark my answer as useful.
Jan 05, 2015 | Heating & Cooling
Hi, I have an LG artcool A09AHD aircon unit and after a while on the heat cycle, the unit stops and shows a circle with a snowflake and a waterdrop within the circle. Does anybody know what alarm tjis is?...
This may just be the defrost cycle for the outdoor unit. In the heat mode, the outdoor unit builds frost on the coil. The outdoor unit senses how much frost has built up on the coil and reverses the refrigerant cycle to allow the outdoor coil to warm up and defrost it. After a short period, the unit then restores itself to the heat cycle. This is normal operation and nothing to worry about. During the defrost cycle, you may feel some cool air inside your home.
Oct 26, 2013 | LG Heating & Cooling
Frost build up
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Determine the temperature setting. The refrigerator should be set to temperatures ranging from 34 degrees to 40 degrees, while the freezer should be below 30 degrees. Adjust the temperature setting which will naturally improve the ice buildup that's been caused by the wrong temperature setting.
Move the refrigerator away from the wall. Oftentimes, this simple action is all that is needed because the unit is not getting enough air circulation behind it. Also, some refrigerators have vents underneath the unit, which are easily clogged with debris. Clean these vents and coils.
Remove food and shelving from the refrigerator and freezer portions of the fridge. If ice build up is happening in the freezer, the drain in the freezer may be clogged. With the unit off, remove coverings to expose drain and pour hot water down the drain hole until it comes out into the drain drip pan under the fridge.
Check the condenser coils. The evaporator coils could be causing the problem of ice build up. If this is the case, professional repair is likely needed to replace the motor, thermostat or other problems within the fridge.
Check this link for a detailed idea:-
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query or else please accept the solution.
Sep 07, 2011 | Refrigerators
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
I think something is wrong with the fridge as nothing seems exceptionally cold even on the highest setting and milk is going off too quickly
Hello and Welcome to FixYa!
The Poor cooling that you are facing is caused due to the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing/opening the panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually shows a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed/designed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (usually a bi-metallic switch) The defrost heater Also you need to clean the dust, lint from the condenser unit by using a condenser brush or a vacuum cleaner to remove all the dust from the unit (it is usually located at the back of the refrigerator). If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. If the problem still persists and the above quoted techniques/tips didn't work,You may need a qualified appliance repair technician to further diagnose the problem.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Sep 19, 2010 | Refrigerators
Whirlpool ED22PQ, 21.7 cubic feet. Freezer is not cold. Sounds like something is trying to "click on", but nothing happens.
unplug your freezer. Move the fridge 1 foot from the wall. Wait 15 minutes and plug again . if it works good , ok . if not you will need to call the technician who will check the starting relay and the compressor
Sep 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
My Frigidaire freestanding wine cooler only seems to cool as low as 53 degrees when I have it set to its minimum temp. The manual says the minimum temp should be 40. Is something wrong with the unit?
YES! Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush
Aug 22, 2009 | Refrigerators
GE side by side
Something has gone bad in the defrost circuit.(Heating element was notorious for this) but could be a timer or thermostat. Frost buildup will cause inefficient cooling as will dirty condenser coils.
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
