Question about GE 31GT660 TV
Screen is too dark
I have a GE 48 inch projection tv. It is approximately 7 or 8 years old. Not sure of exact age...it was my mother's. The color is very dark. If you try to adjust the picture controls it just makes the color look worse....not helping the brightness. I'd hate to get rid of the tv, but it's barely watchable anymore. Any help or advice is appreciated!
  • 104 Answers
With a flashlight at the back of the set often times there is an adjustment you can make WITHOUT having to open the set!!!
look for a little hole in the back of the plastic cabinet labeled SCREEN then with a flat screwdriver holding only the plastic handle, insert it into the hole and SLOWLY rotate until the screen brightens up until it is watchable.
This is compensating for age in the picture tube. you may get a few day or a few more years! of a much better picture.
If you start seeing some thin lines on the screen then back off you have gone too far. Do this adjustment with the brightness and contrast controls on the menu turned up all the way.
it is also safe to play with the focus adjustment right next to the screen if thing seem a little blurry. you will need two people one to watch from a distance for best picture.
Posted on Feb 12, 2009
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Rylee just advised me that I had a convergence problem with my Panasonic PT-47WXC43 which could cost 300-350 to repair. The TV is approximately 7 years old and I'm aware there are a lot of bulbs and other...
I replied your previous question, click HERE to read it again.
If tv shows bright picture in proper focus then it would last few more years as it is rear projection tv that has 3 picture tubes (red-green-blue) to project color picture on front screen.
Its your choice to have new tv instead of repairing this one and yes, its correct that 32 inch tv is available under 700-800 dollars.
Hope these info will help you.
Thanks.
May 26, 2010 | Televison & Video
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
48 inch toshiba with color alingment problem
Hello:
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Televison & Video
Tv screen
this is your convergence amp
for cheep repair call
719 687 6997
Nov 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Old toshiba
Hi Veronica,
I need to know exact model number of your Toshiba TV to help you out.
You can find it at back of TV on some kind of sticker.
Oct 11, 2008 | Zenith R49W36 49" Rear Projection HDTV
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
Color convergence
RICKY-SOUNDS LIKE THE USUAL CONVERGENCE IC FAILURE.TRY LOOKING IN W/BACK OFF TV AND YOU'LL SEE COUPLE OF STK392-??? IC CHIPS,LOCATED ON A BIG METAL HEAT SINK.RETRIEVE THE EXACT PART # AND YOU CAN ORDER THEM AND INSTALL THEM YOURSELF IF YOU ARE GOOD AT SOLDERING ELECTRONIC PARTS,IF NOT BEST BET IS CALL AN EXPERIENCED JVC TECH.JOE TV
Nov 27, 2007 | JVC AV-48WP74 48" Rear Projection...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
GE 31GT660 TV Logo
170 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
