Question about Yahoo Messenger
Installation stuck at 99% in vista h premium
Set up of yahoo messenger installation stuck at 99% on screan,but on task bar a set up icon is there showing yahoo messenger installation-97%..and while uninstalling it it showa error install.log file missing.\,and even doesnt uninstall
  • 1 more comment
  • Anonymous Feb 11, 2009
    stuck at 99% in vista h premium problem
  • deeliteful1 Feb 12, 2009
    When i go to install Messenger 9.0 it stops around 80% and says the configuation is incorrect and that i need to go through an administrator's
    program. I do not have Vista. Yahoo 9.0 mail was installed with no problems.
  • Anonymous Feb 12, 2009
    Hi, I have exactly the same problem on vista h edition. Not sure if it is a vista problem or a problem in yahoo installation.
    Pl. mail me at asvramana at rediffmail.com if you have the answer.
    Regards,
    Venkat
I can login another yahoo ids but only the problem with shakeel_khilwath id please give me solution
Posted on Feb 13, 2009
I just want to have an icon of yahoo email on task bar without downloading all the tool bar
Just make a desktop shortcut with this address on it:
http://mail.yahoo.com
Then grab that icon and drop it on your taskbar is using windows xp/vista. If using Windows 7 right click on the icon and set "pin on taskbar" option
Mar 15, 2011 | Computers & Internet
I need to install of yahoo messenger for windows vista home premium
1. Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. Thiswill bring up the Windows Security window. Click the "Task Manager"button and then click the "Task Manager" tab. 3. You will see a list offiles/applications. These are the applications running in the background onyour system, whether they show on your taskbar or not. Any one of theseapplications could be causing a conflict with the Yahoo! Messengerinstallation. 4. Click the top item on the list tohighlight it. Then hold the "Shift" key down and click the last itemon the list. This should highlight the whole list. 5.Click the "End Task" button. This will temporarily close allbackground applications on your system. 6. Click the "X" in the upperright corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should notexperience the same issue that you had before. 8. After Yahoo! Messenger is installed,runregistry cleaner reginout also rebootyour system. All other background applications will return to their originalconfigurations.
Feb 22, 2011 | Yahoo Messenger
Yahoo messenger wouldn't appear on screen. It comes up in task bar as a blake. Also icon wouldn't let it come up.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Jan 30, 2011 | Yahoo Messenger
Yahoo messenger 10 crashes immediately after sign in , am using vista home premium
I am suffering this, the best thing I could do is go to the Yahoo Messenger directoru and set the yahoomessenger.exe compability mode with windows xp sp3.
suddenly the y!m got tamed. I'm using y!7m with win7 64 bit right now :)
Sep 20, 2010 | Yahoo Messenger
I want to put icon yahoo masengerin to my screan pc
To put a Yahoo Messenger icon on the desktop of your PC:
  1. Click the start button in the lower left corner of your screen
  2. Click All Programs
  3. Locate the Yahoo Messenger program
  4. Right click on the program
  5. Select Send To > Desktop (create shortcut)
Aug 27, 2010 | Yahoo Messenger
My icon for messenger on my task bar has disappeared.How can I get it back? Many thanks for your help. Pat Hopper
Hi
Find program to path C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe
then drag the program to the taskbar
Aug 11, 2010 | Microsoft Windows Vista Home Premium...
IM box will not appear
The system tray (in short: systray, nowadays also called taskbar notification area) is the icon strip normally located near the right end of the task bar, next to the clock.
Some Windows XP installations show a peculiar defect in that some systray icons disappear or, rather, do not appear, when the system is booted and the user logs on. The problem is even more prevalent on systems with autologon. The most frequently affected icons seem to be the speaker icon (sound volume) and the power/energy icon.
This has nothing to do with the hide inactive icons settings. The defect shows up when you don't have any icons set for hiding.
In any case, please make sure for now that you haven't activated that setting. Right-click the task bar, click on Properties, uncheck the last check box. You can reactivate it later if all other problems are identified or solved.
Check your Startup folder and the starter registry entries through Start, Run..., type: msconfig, press Enter, to check whether the programs are really started at system start, or use Task Manager (Ctrl + Shift + Esc) to see whether the processes are running.
Jul 03, 2010 | Yahoo Messenger
Why my yahoo messenge 8.0 always stop working? what version of messenger match to my windows vista home premium?
download the new version of yahoo messenger from http://messenger.yahoo.com/ and install it.it works fine with windows vista. gudluk!
Feb 19, 2010 | Yahoo Messenger
M having windows vista yahoo messenger 8.1 is not intalling
Right Click in Yahoo Messenger ,exe And go to Trobulshuting Complier
Plz Install
Enjoy........
Aug 17, 2009 | Microsoft Windows Vista Home Premium...
My Yahoo Messenger wont open?but earlier I still can use it but now when I click the icon nothing is happening.pls advise..
Your process probably just froze.
Press (on your keyboard) Ctrl + Alt + Delete at the same time and the task manager should come up. If you have windows vista then select task manager when given a list of options.
--> Go to the Tab that says "Processes"
--> Look for the name "YahooMessenger.exe" on the left hand side. and click it to highlight it.
--> Click "End Process" on the bottom right hand side.
--> Its going to ask do you want to end process. Just say yes. Or it might hesitate for a minute and say the task is not responding. Simply hit "End"
--> Once you no longer see "YahooMessenger" in the list, double the yahoo messenger icon to bring it back up.
If this still does not work your going to have to unistall and re-install the program.
Mar 27, 2009 | Yahoo Messenger
Yahoo Messenger Logo
264 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
