Question about HP LaserJet M4345 MultiFunction Printer
Help for setting trays to switch to the next bin
I need to find the Help for setting trays to switch to the next bin when the first is empty on the hp LaserJet 4345 mfp.
    Genius:
  • 2,120 Answers
In Printer Properties set trays to auto
Posted on Feb 11, 2009
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Where is mfp 4345 scaner driver
You need to specify what are you looking for. Is it the driver it self, for specific platform/OS. Or do you need to locate the driver which is already installed on your computer?
Drivers Software Firmware for HP LaserJet 4345 Multifunction Printer...
Apr 28, 2014 | HP LaserJet 4345mfp Printer
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
PRINTER COULD NOT AUTOMATICALLY EJECT PAPER HP 4345, with error code 13.20
Check inside the MFP (manual feed tray) for a scrap or a whole sheet of paper.
There is one of three sensors that is sending a paper jam notice to the printer.
Nov 05, 2011 | HP LaserJet M4345 MultiFunction Printer
We just installed an HP 4345 mfp. Every job we print requires us to go to the printer display and choose a different paper tray. Tray 1 is the manual feed, Tray 2 is bond and Tray 3 is yellow. What do...
If you are setting the trays for non-plain paper then you need to ensure that your print driver is set to match the paper types that are set on the printer. Otherwise the printer will always ask you to confirm which paper you want to print on.
Aug 09, 2011 | HP LaserJet M4345 MultiFunction Printer
I have an hp laserjet 4345 mfp which gives error code 58.04.Please help me
Hi
Follow the below solution
Turn the MFP off, and then turn the MFP on.
58.4 = Engine power supply
Check the power supply connections
Replace the air-temperature sensor.
See Main fan (FN101) and reversing unit
do rate my solution
Jul 07, 2011 | HP LaserJet 4345mfp Printer
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
Hp LJ 4345 mfp vertical line down printed copies
Dirt.
Open the ADF, the top of the scanner/copier.
The ADF glass is the thin strip of glass on the left. Damp cloth with windex or any glass cleaner. Scrub the strip of glass.
Dec 04, 2009 | HP LaserJet 2840 Printer
Automatic switch to next bin when one empties
Touch MENU, then scroll to CONFIG DEVICE then to SYSTEM SETUP then to TRAY BEHAVIOR then to the top setting set it to FIRST from EXCLUSIVELY
Feb 10, 2009 | HP LaserJet M4345 MultiFunction Printer
HP LaserJet M4345 MultiFunction Printer Logo
267 people viewed this question
Seeker5211
Seeker5211
