Question about HP Deskjet F2180 All-In-One InkJet Printer
HP F2180 not scanning
Although I can print ok, the launch screen does not open and I cannot scan documents from the buitton mode on the unit. The steady light fllashes, but does not prompt the scanner to operate.
  • 1 more comment
  • arcanne Feb 12, 2009
    Unfortunately, the suggestion did not work. And to reitterate, the pop-up window does not show either.
    Thank you for your support anyhow.
  • Anonymous Mar 25, 2009
    YES THAT WORKED! But i need the document to be scanned ONTO my computer.....any ideas?
  • Cubicle99 Apr 15, 2009
    franx, THANKS! Excellent suggestion.
    I went through HP technical support on this, and they sent me through an entire series of steps including uninstalling and reinstalling the software for my F2120, none of which worked at all to solve the scan issue.
    But if you hit the black or color buttons above scan, the scanner will scan your document and then print it out. It's not allowing it to be saved to the PC, but at least that's a partial solution.
    HP knows that these machines are not compatible with Vista by the way for anyone who researches it.
    Problem Solver:
  • 6 Answers
I was having the same trouble. All you do is turn the printer on and make sure there is paper in the tray for it to print onto (obviously), then lift the lid (keeping it open) and place the piece of paper you are scanning onto the glass. The side you want to scan needs to be face down in the bottom left hand corner. Then instead of pressing the scan button (which did nothing for me either) press the black or colour button that is above it, depending on whether you want to scan in colour or just black and white. Worked for me! Hope it works for you too.
Posted on Feb 11, 2009
Why when I try to print off an e-mail it says printer is 'paused'
It seems that the printer is set to pause mode...
Download the print and scan doctor tool from the HP Website and run the same .. it will fix the issue
Download Link: www.hp.com/go/tools
Oct 12, 2014 | HP Deskjet F2180 All-In-One InkJet Printer
Copy on HP Laserjet 200 Color MFP
If you just want a single copy of the document, place the page face down on the scanner glass or face up in the document feeder. Then press Copy on the all-in-one (for the M276 this is on the touch screen). If you need to adjust the image quality/size or paper size, press Settings. Then press Image Adjust or scroll down and touch Paper. When done adjusting any setting, press OK. Then press Black or Color depending on your source page.
If you want to scan to a computer first, you'll need to make sure that the full software is installed on that computer. Then launch a scan from the computer before using the touch screen's scan button. You need to set up the default scan options before the scan button works. (There is a monitor program "hears" the button and it needs to know the scan defaults and destinations to launch the appropriate parts of the software.)
Note: many all-ones will not work if there is a problem with the print system.
I hope this helps.
Mar 18, 2014 | HP Color LaserJet Pro 200 M275nw
I can not scan from my HP Photosmart C7180 All in one. Mac OSX 10.6.8 I can copy, print but not scan.
Launch the OSX system preferences, click on the Print & Scan Icon located in the Hardware row, select your printer in the left hand column, click the Scan button above the right hand box, click on the Open Scanner button, a new window will open, click on the scan button in the upper right hand corner of that new window, set your document on the flat glass panel of your multi function printer/scanner, and click the scan button located in the lower right hand corner of the window, once scanning is complete, your document image should appear in a new window and save the image from there.
Dec 22, 2013 | HP Photosmart C7180 All-in-one Printer Fax...
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have an hp psc 1210, I have managed to figure out how to print from my comp, but how do I scan things to my computer
Scanning depends on a few things (OS, drivers). Did you install the full-featured software or the generic driver from the OS? (See the HP support site: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=90764& for drivers/software.) If you have installed the generic driver and a full software package is available, uninstall the driver, unplug the all-in-one from the computer and install the full software. Then reconnect the data cable.
Place the document to be scanned face down on the glass. (Document feeders need the document face up with the top edge entering the feed first.)
Depending on the setup, you can launch the software from your computer. Double-click on the icon on the desktop or (in Windows) Start > All Programs > HP folder and then click on the HP Director. (Once this software is set up for the scan destinations, if the monitor program is running, you'll be able to press the scanner button on the all-in-one to launch the scan. This is under Settings) Once the program is running, click Scan Picture or Scan Document depending on the item to be scanned. Adjust resolution and other settings as needed - try the default first. Click Scan. If doing a preview scan then click Accept when satisfied with the settings.
If you do not have the full software available for your OS or simply do not want to use that software, you have some alternatives. Windows XP, Vista and 7 all can acquire scans in Paint. (Open the program, then File > From Scanner or Camera) Some versions of Vista and Win7 included Windows Fax and Scan which also acquires the scans (just click New scan). Vista has another program that can acquire scans (Photo Gallery IIRC). Macs may have similar software available. In both cases, third-party software is also available.
If your computer doesn't see the scanner, check the cables. Scanners require bi-directional communication with the computer so a cable that allows printing can be a problem with the scanner. Try a new cable or plugging in to a different port. If you have a USB hub or print server, try a direct connection.
I hope this helps.
May 31, 2010 | HP PSC 1210 All-In-One InkJet Printer
Which is the scan button mp520 canon printer
Easy Scanning with One-click You can complete from scanning to saving easily by simply clicking the corresponding icon.
1. Place the document face-down on the platen.
2. On the Windows desktop, double-click (MP Navigator EX 1.0).
Alternatively, on the Windows taskbar, click Start, point to (All) Programs, Canon Utilities, then MP Navigator EX 1.0. Then click MP Navigator EX 1.0.
The MP Navigator EX navigation mode screen or one-click mode screen opens.
3. Point to One-click.
4. Click the corresponding icon.
Save to PC
Scan documents or photographs and save them to a computer.
The Save dialog box opens when you click this button. Specify the scan/save settings and scan.
Save as PDF file
Scan documents, save them as PDF files and start the specified application.
The PDF dialog box opens when you click this button. Specify the scan/save settings and scan.
Attach to E-mail
Scan documents or photographs and attach them to e-mail.
The Mail dialog box opens when you click this button. Specify the save settings and e-mail software program, and scan.
OCR
Scan text documents and open them in OmniPage SE by default.
The OCR dialog box opens when you click this button. Specify the save settings and application, and scan.
May 18, 2010 | Canon MP520 All-In-One InkJet Photo...
How to scan a document
What operating system are you using?
Here's a list of options for you.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Deskjet+F2180+All-in-One+Printer&opname=HP+Deskjet+F4280+All-in-One+Printer&qry=scan&method=prodFinder&enc=UTF-8&ctry=us&lang=en&dlc=en&sni=3390949&search=0&submit.x=0&submit.y=0
You probably want to go to one of the "how to scan without using HP software" or "how to scan with Solution Center". Choose the option that matches your operating system.
Dec 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Every time I rurn my computer & f2180 printer on it prints a scan page. how can I stop this. I have uninstalled the printer and reinstalled it but still it prints a scan page. can anyone help
is this a test page or is it scanning? When you installed the unit did you follow all the steps because some all in ones won't rest until they have done all the 9 yards.
Check you printer default settings. Got to control panel>printers>properties for the printer you have installed. It may have an option for the printer to print the test page on startup
How do you get the Canon Pixma mp500 to scan?
Scanning images,
About Scanning images
You can scan images from the machine to a computer without printing them and save them in popular formats. Scanned data saved on your computer can be processed using image processing software. Furthermore, you can use the OCR (Optical Character Recognition) software to convert scanned paper documents to text data.
* Before scanning
Before scanning images, confirm the following :
- Are the necessary software (MP Drivers and MP Navigator) installed ?
If the software is not installed, install it.
- Does the document to be scanned meet the requirements for an original to be set on the Platen Glass ?
- Is the machine connected to a computer correclty.
Confirm that the connection between the machine and the computer is physically secure.
Scanning Methods.
A) Scanning Using the MP Navigator
MP Navigator enables you to scan in documents loaded on the Platen Glass and view images saved on your computer or on a memory card. Scanned documents can be previewed and easily printed and edited according to your needs.
You can use the supplied application softwares to edit or print the document you have scanned.
Windows : Double-click the [MP Navigator 2.0] icon on your desktop to launch MP Navigator.
Mac : Select [Applications] from the [Go] menu, then double-click the [MP Navigator 2.0] icon to launch MP Navigator.
You can launch the following application software from the MP Navigator.
* Easy-PhotoPrint (Photo Printing)
* ArcSoft PhotoStudio (Photo image editing)
* ScanSoft OmniPage SE ( Converting scanned document to text)
- This application software may not be supplied with teis machine in some country.
Note : If you did a [Custom Install] and only installed the MP Driver and MP Navigator, these application software were not installed and thus cannot be launched. To launch any of the above application softwares from MP Navigator, do a [Custom Install] once again to install them.
For detailed operations of the MP Navigator, refer to the Scan Guide.
B) Scanning Using the Operation Panel of the Machine
You can scan documents to your computer by using the Operation Panel.
Important : Do not insert or remove USB cables when scanning images with the machine connected to a computer, or when the computer is at sleep or standby mode.
*If you are using Windows XP
The program selection screen is displyed the first time you press [Color] or [Black] on the machine.. Specify the [MP Navigator 2.0] as the application software to use, check [Always use this program for this action], then click [OK]. From the next time, MP Navigator is automatically started.
*When using Mac OS X
For the machine to start scanning when [Color] or [Black] is pressed, you need to set MP Navigator as the starting application software in Image Capture under [Applications] of Mac OS X.
1) Press [ON/OFF] to turn on the machine.
2) Load the documents on the Platen Glass.
3) Select the scan option.
a) Press [Scan].
The scan operation selection screen is displayed.
b) Use Up or Down arrows to select the scan operation, then press [OK].
Scan standby screen is displayed.
Save to PC : The document is scanned and saved.
Save as PDF file : The document is scanned and stored as a PDF file.
Attach to E-Mail : The document is scanned, and the image is attached to an e-mai using the e-mail application software.
OPen with application : The document is scanned and displayed on the registered application software.
4) Press [Color] or [Black].
The document is scanned. The settings configured from MP Navigator apply when scanning.
Important : If with some types of original the position and size of the image is not scanned in correctly, please refer to the "Selecting the Behaviour of the Operation Panel with Mp Navigator " in the Scan Guide (on-screen manual). and change the MP Navigator [Document Type] and [Document Size]] to match those of the original being scanned.
Note : The operation to be performed after scanning the document depends on the scan operation setting you have selected in step 3. For details on how to modify the operation settings, refer tp the Scan Guide on-screen menual.
C) Scanning from an Application Software
You can scan an image from TWAIN-or- WIA (Windows XP only) complaint application software and handle the scanned image in the application software. For detailed operations, refer to the Scan Guide (on-screen manual).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
HP Deskjet F2180 All-In-One InkJet Printer Logo
429 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
