Question about Ricoh Aficio AP2600 Laser Printer
Ricoh AP2600 printer gives an error message of SC322
The printer will send the paper through the machine but nothing prints, and it gives the error message SC322
  • 2,404 Answers
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Posted on Feb 10, 2009
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
The red printer light goes on when I try printing envelopes from stamps.com and nothing prints. It worked on Friday. When I press the red lighted button, the message says paper size/type mismatch, change...
This happened because you are sending a paper setting to the machine that do not exist.
Go to the PROPERTIES of the printer driver and change the paper settings.
Hope this helps you.
If this does not help reply to me.
(For give you more detailed help i need to know what driver you are using - RPCS or PCL)
See you.
Apr 25, 2011 | Ricoh Aficio MP 161 Black and White Copier
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
Ricoh Ap2600
Fuser overheat error, Replace the fuser. -Carl
Jun 22, 2009 | Ricoh Aficio AP2600 Laser Printer
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Laser AP2600 prints XXXXXXXXXXdown sides of paper
Sounds to me there is a compatitbility problem with the program try to download another driver.
-Carl, please let me know if this helps.
Jan 23, 2009 | Ricoh Aficio AP2600 Laser Printer
Sc322
1st laser synchronization error.  It is an expensive part to replace and in most cases its cheaper to by a used Ricoh.  There are some 1035s and 2035s out there that run around $700 in American dollars.  If you can find them.
It's possible there could be something going on with the power supply.
The toner spill can vacuumed as well as the optics and the rest of the machine can be cleaned simply with cleaner.
Nov 01, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio AP2600 Laser Printer Logo
379 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
