Question about Philips Magnavox DVD/VCR Dual Player
I have tried using the timer recording on my new unit and it
Seems to be okay but when I try to play the dvd back there is nothing there. Why is it not playing back?
  • 728 Answers
Try recording a dvd without putting it on timer to see if it will record for a test. If it does record, make sure that the timer is set correctly and that you do not have the am/pm mixed up. If it does not record, then try using a different recordable/re-writable dvd disc and see if it burns then.
Posted on Feb 10, 2009
  • Philips Master
  • 19,396 Answers
Give me the model, so that I can find the manual.
  • Ginko
    Ginko Feb 10, 2009
    Check your cable connection, and ensure the unit is set on the right input channel when you start recording, or you risk to record only blank onto the dvd.
  • 565 Answers
The connection beetween the devices is not set up correctly then its recording empty
  • Teet Bergmann Feb 10, 2009
    if u tell from where u wanna record i can tell u how to connect it that it records.
Why won't it make a timed recording?
Check that the time and date are set correctly and try again. Let us know how you get on by posting your results.
Jun 28, 2015 | Samsung DVD-V3650 DVD Player/VCR
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
I put in a new disc to record and ( and get "Recording error, can not record on this disc." E 4 54039000. Seems like it doesn' want to format as usual. This just started about a 2 weeks...
E4 error code means that the disc isn't being read, because the unit is dirty or the optical eye is going out .You have to get a cleaning kit and then proceed.
you may try this:
unplug from wall, wait 15 minutes, plug back in, and reset the clock,
or
The disc must be DVD-R with an R4.7 under the logo and they MUST be 4X or 8X specific .... the cannot be 1X - 8X or 1X - 16X or note up to 16X .... the disc box must state 4X or 8X ONLY .... and yes they are hard to find for sure
Mar 16, 2011 | Toshiba DR570 DVD Recorder
I was wondering if you could help us with our DVD recorder. Its a Toshiba DVD Recorder Model: D-R18DTKB and up until recently has been in good working order. A while back I bought some Sony+RW...
Hi Tony
Although I am a member of this site I came across your post while searching Google for answers to the same issues as you are having.
From what you say and what I have tried I can only put fault with the DVD recorder itself and probably the LASER.
This thing just seems to hate reading recorded media of almost any format including those which it's stickered front panel boasts about. It also doesn't leave you with many other options as there is no USB port either.
I dont use the unit to record or the Freeview facility and never have as we have Sky+ and no TV ariel.
I bought it for the varied formats of video it says it can play but out of 6 different formats that I recorded onto DVD with my PC (and I am an advanced user and work in I.T) it only played back one and badly which was a mpeg-1.
I put the same 6 disks into my sons (apparantly DVD only) player bought from ASDA for £15 and it played 4 of them perfectly as good as the originals!
Logically this would suggest this model is a Lemon. I just hope your not a £130 light lemon as I am!
Oct 27, 2010 | Televison & Video
Disc will not finalize error comes up as e19 can not record to the disc. the show is actually recorded and will play back just not finalize. have tried -r/ +r and + rw and get the same message. unit being...
You don't need to delete timer rec programs to Finalize, Format or Erase discs!
Set the Mag 2160A (mfgd in 2009) to Source L3 (DV) using the Source button on the remote.
To Format a RW disc, set unit on L3 BEFORE inserting a new disc cuz the Formatting op is automatic and starts right away. It's also so short on a +RW (longer on a -RW) that you could think it had been Formatted.
Finalizing requires you to select it from the Disc Edit menu, so you can set the unit on L3 after inserting a disc for this op.
More into on all aspects of setup and op are here:
http://www.avsforum.com/avs-vb/showthread.php?t=940657
Apr 29, 2009 | Televison & Video
Sansui VRDVD 4005 Recorder
I've had this problem myself and a list of others. FYI, I've found it easier to use dvd-rw discs
for any mistakes you might make. Use Video mode (not VR mode) if you want to watch them
on a Computer or other DVD again and you have to Finalize disc. As for your problem, if all
else is okay, try removing your disc and unplugging the unit. I've done this numerous times
for odd reasons something wasn't working right. I'm not sure how long you have to keep it
unplugged. Try 10 minutes and you'll have to wait 30 minutes or more if you want the clock
to sync up on its own but you can set the clock manually. I've done this for a blinking
REC light in the VCR mode after trying the TIMER REC button.(it shouldn't be blinking
when the unit's working properly) This gets to be a pain and I've had to do this sometimes
2 days later or 6 months later. It's not a perfect unit. By the way, if times an issue, reset the
clock manually as soon as it starts blinking. This will cut your reset down to 11-12 minutes.
Hope this helps.
Sep 09, 2008 | Sansui VRDVD4005 DVD Player/VCR
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Apr 20, 2008 | Samsung DVD-HR720 DVD Recorder
Protron PD-DVR100
misaligned laser causing it to stop and restart back to blue this unit would need a new laser put in it or for it to be recalibrated.
Josh
Feb 28, 2008 | Protron PD-DVR100 DVD Recorder
Video recorder wont record...jvc GR-D32U
Okay, you have listed your device in the wrong category. What is it you have?
Jan 25, 2008 | Computers & Internet
Philips Magnavox DVD/VCR Dual Player Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
