Question about Motorola Mobility RAZR V3
How do I increase my ring tone volume on my Moto Razor .?
I work in a noisy place so I need a loud ring to hear my incoming calls. How do I set my ringer volume to loudest.?
    Scholar:
  • 61 Answers
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
Posted on Feb 10, 2009
You can not hear anything on the hand set but thepeople calling can hear you
Dear Karen,
If you have a standard cell phone, the problem is likely your volume button.
The volume button controls the ringer loudness, and the same volume controls all of your calls incoming.
If your ring tone is loud, probably your volume is turned down for you to hear.
The same button controls both functions.
To change it, next time someone calls you, try pressing the volume button to "louder" WHILE they are talking to you.
God bless your efforts.
May 12, 2016 | Cell Phones
On incoming call phone lights up with number and you can answer but no ring tone
Hi David.
if the all setting are ok??
then you have to check its ringing tones ,simply go to ringing tones under the settings and try to change the tone and you can increase the volume in this menu too.
if no ringing ton hear.
it is hardware issue.
regards.
nuwan
Jan 16, 2014 | Cell Phones
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
To increases volume
first of all u can increase volume during call by pressing right button (middle one). but i think ur phone is set to max and u dont hear much - in this case probably some "metal dust" sticks on your speakers membrane - open case clean speaker gently or replace with new one...
Feb 07, 2011 | Nokia 1600 Cellular Phone
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Jan 19, 2010 | Nokia 1661 Cell Phone
Can't hear ringer
I had this same problem with my Blackberry. You should check the settings on your sound and volume for incoming calls and make sure you have a tone set. You can also find a way to amplify your ringtone by hooking it up to your computer. If you dont' hear anything at all, then check the buttons on the side and see if that increases the volume. Please rate my answer.
Oct 12, 2009 | RIM BlackBerry 7290
Ring voloume
ave you set it from inside the profiles for incoming calls. have you turned up the volume from the side of them phone when making or recieveing calls. set your pofile with all the loud tones and then it should work again.
Jul 20, 2008 | Lands Phones
Motorola Mobility RAZR V3 Logo
274 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
