Question about Canon PIXMA iP1300 Printer
My printer keeps telling me the ppr is jammed
My printer keeps telling me that i have to remove the jammed ppr but it keeps rolling the ppr out without printing...ive checkd the rollers of the printer but i cnt seem to see anythng jammed in it...i tried to remove the printer cover but cudnt as i cnt seem to figure out how to remove it...can anyone please help me? thank you.
  • izmah_225 Feb 12, 2009
    thank you. do you know how i can fix that problem? :)
    Sergeant:
    Champion:
  • 237 Answers
There is a sensor flag either stuck or sticking and it is causing it to give a false jam error
Posted on Feb 10, 2009
  • John Cole
    John Cole Feb 12, 2009
    Look inside there and see if you see a plastic piece hanging it should be right as you load the paper and follow that path. And see if you can find anything that looks stuck or out of place
How do i adjust heat settings in xerox 6110
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
Jun 21, 2014 | Xerox Phaser 6110 Laser Printer
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
Paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 14, 2010 | Canon SELPHY DS810 InkJet Photo Printer
Jams when duplexing on ricoh mp161
if you are talking the origanal in the DF check for staples or ppr clips inside the DF, or if it is jaming the copies try fresh ppr clean the rollers.
Apr 08, 2010 | Ricoh Aficio MP 161SPF Color Copier
Paper is all wrinkled and jammed up just before exit...can't pull it out and no access. Different than a "regular" ppr jam
In most cases, it's easier to pull the jammed paper if you turn the printer OFF and the pull the paper VERY SLOWLY
Apr 02, 2010 | Canon imageCLASS D780 All-In-One Laser...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
IN my office I have HP Laser Jet 1020 plus, A4 paper got jam
you need to deassembly the printer by removing back screws adnd open cover to access fuser unit.
Jun 26, 2009 | HP LaserJet 1020 Printer
My printer always tells me paper jam
the issue can be found when the paper feed rolls in the printer or the internal encoder strip are dirty.
Please try the following:
- open the backdoor of the printer
- also open the front door
- unplug the power chord without shutting down the printer
- now clean the paper feed rolls inside the printer with a soft rubber
- turn the rolls some times (10 tries or so) from down to up
- close the backdoor
- move the cartridge cart some times from one side to the other
- now you see a transparent strip over the metal bar
- this strip you can clean with cleaning alcohol
(be carefully! don't loose the strip or take too much alcohol)
- now let the printer dry over night (let it be open)
- next morning, close the front door
- press # and 6 at the same time and hold them
- keep them pressed and plug in the power chord
- keep them pressed until you see "semi nvm reset"
done
Hope it helps,
Henning
Feb 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Paper jam, paper was removed still says paper jam
some small partical must be their on printer papper sencer ... or may be senser spring in jammed
clean it
Dec 02, 2008 | Office Equipment & Supplies
Paper wrapped around the red roller
lift the cover remove all the cartridges and the drum unit slowly and carefully and slightly pull the upper side of the paper not the lowerside and if it is rolled completely you have to open the heater unit to remove if you donot have any technical knowledge do not try because the red roll you are taking is a costly thing,call the service technician and get it repaired that would be more cheaper.
Aug 08, 2008 | Samsung CLP-510 Laser Printer
Canon PIXMA iP1300 Printer Logo
77 people viewed this question
old marine
old marine
