Question about Akai PT5492S 54" Rear Projection Television
TV will not turn on. Clicking noise heard from inside.
Worked fine for 5 years. Started getting slower coming on. Now will not
come on at all. Clicking noise heard coming from inside guts of tv.
Any ideas? Thanks.
  • 4,234 Answers
These sets use what is called a "switch mode" power supply. In order for them to work there is a capacitor that "kick" starts the process. If that cap goes bad, the power supply will not start up. Also, there are other caps inside that maintain the oscillation required for the power supply to work. There are 2 options for you here.
1) Replace the entire power supply module.
2) Repair the existing one.
Sicne these types of power supplies are not the easies to diagnose or repair, I would suggest that you replace the power supply module. That should resolve the problem.
Please note that there are other causes of the reported problem, but hte power module becoming defective is the most common.
Dan
Posted on Feb 10, 2009
Tv went blank and started making a clicking noise
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 01, 2014 | Proscan PLED4274A 42" LED TV 1920x1080, 60...
Noise when coasting
Could be throw out bearing.
Jul 25, 2017 | Chevrolet S 10 Cars & Trucks
Samsung LCD HD TV Model # LN-S4041D > 4 years old - working fine until today - While watching TV, I heard 2 loud beeps and the TV image was lost - initially frozen pixels and some moments later .......
Th clicking is from the power relay. You will have to open it up, the first place to look will be the power supply module, look to see if it has any bad caps with leaking/bulging tops first, caps can look OK but can be bad due to high ESR.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 17, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
1994 honda goldwing 1500 se starting problems
How is your battery? Sure sounds like it's too weak to turn over the starter.
Assuming that it always started just fine and then the battery is the problem. Many times it slows down gradually--like it turns over slower and slower until the battery finally has no power.
Try charging it.
Oct 08, 2009 | Sport & Outdoor - Others
Blue vertical lines on tv when turned on....now no picturs.
the guns gone bad inside needs to be replaced.
Apr 22, 2009 | Televison & Video
LG home 5 disc dvd changer
try to clean the dvd player it could be the lens that is having a hardtime reading the disk and it causing the noise
Jul 21, 2008 | LG LXD5230 System
Tv shutting off on its own.
Was talking to one of the experts on the "chat live now" tab and he suspects a power supply problem. Who knows??
May 02, 2008 | Panasonic PT-60DL54 60" Rear Projection...
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Clicking noise+horizontal flashes
What you are hearing is the high voltage arcing a bit. This is often caused by dust buildup on the high voltage components, & is not harmful. A good cleaning with compressed air will cure it, but this is not a do it yourself job, because dangerous voltages are present inside any TV.
Jul 13, 2007 | RCA F36450 36" TV
Akai PT5492S 54" Rear Projection Television Logo
413 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
