Question about Vtech V.Smile Pocket
Vsmile keeps turning off
Whether it's plugged in or when batteries are in it, unit keeps turning off. replaced it once, and a month later the same thing happened to that one too
  • 6 Answers
Here's the solution to your V smile: Oxidized connectors! Remeber the original Nintendo back in the 80s? You had to repeatedly reinsert the cartridge so that it would work properly. The V smile has the same problem. They use tin plated copper contacts on the game cartridges as well as the internal connector. All newer electronics use gold plated contacts because gold does not oxidize (rust, corrode). You'll need a very fine sheet of sandpaper. Start by lightly sanding the game cartridge connector (you have to expose the contacts by pushing the plastic part in). Make sure you wipe the contacts clean with a rag, and do not touch the contacts with your fingers! Then you have to do the same with the console's internal connector. The danger here is bending one of the pins inside so be very careful. The real solution to this would be to replace the connector but no one sells it (checked ebay, Vtech). Should last a couple of months to a few years, depending on relative humidity and use. If your V smile turns on normally without a game cartridge, then this is your problem. Symptoms vary from no power to corrupted graphics to no sound as well as random turn off (with a cartridge, no problems without a cartridge). I've done a few lately and all are working like new. Let me know how it goes, but I take no responsability for bent pins, damaged connectors, fire, earthquake,...
Posted on Sep 14, 2009
  • m_woolacott3
    m_woolacott3 Apr 08, 2013
    Thank you so much! Our kid's Vsmile had exactly this problem - turned on perfectly with no cartridge, but refused to do anything as soon as any cartridge was put in! When we saw your suggestion on here, we just had to try it. My husband found reaching the internal connectors difficult as he couldn't find a way to get at them internal, so he did his best externally, by pushing the cover back, but it worked! We now have two very happy small people! Thanks again for the great advice!
I called v tech was told to take batteries out of system, unplug from outlet. then press and hold down the on button for 1 minute, after 1 minute, plug back in or put batteries in, this should re-set v tech to original settings.
Posted on Feb 22, 2009
I did take the batteries pressed buttons and still the vtech won't stay on!
Posted on May 28, 2010
  • starflower7 Nov 07, 2010
    This is a simple and easy fix! It worked for us, but I don't understand why V-Tech doesn't tell their customers this! I guess they want you to buy a new one, but most people get disgusted and buy from another company! V-Tech get with the program and be honest with your customers. You have a technical problem that either needs to be fixed or you need to inform your customers that their cartridges need to be cleaned periodically!!!!
I have plugged the v tech in to the tv and put batteries in the bottom but nothing works
This system can be frustrating because if you don't do things in the right order, it won't work. I wrote the instructions in permanent marker on the side of mine. Start with the TV and Vsmile OFF
step 1) put the cartridge in and make sure it is all the way in.
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work you may have to take the batteries out and it seems to clear and then follow the steps again. It is easier to buy an adapter instead of batteries so if you need to clear it you just unplug it and start over. Good luck!
Dec 30, 2010 | Vtech V.Smile TV Learning System
My Vtech vsmile didn't work a the time I push the power button never happend my batterie are test and are brand new an i try to connect direct with a power supply never work again
There are problems with the power adaptors. Did you use a VSmile power adaptor, or something that just seemed to fit the unit? Using the wrong power adaptor (like unknowingly plugging a Leapfrog power adaptor) into the unit can cause damage to the Vsmile Board.
Push and hold the power (smile) button for one minute, then install fresh batteries. if it powers back up, then try:
Dirty Smartridges (the game cartridges) are to blame for about 90% of VTech Vsmile products not powering up.
In some instances, the cartridge slot on the unit itself can become damaged and will cause no power up.
Kids (of all ages) can dirty a smartridge in less than a second, and render the whole system dead.
Sep 30, 2010 | Vtech V.Smile TV Learning System
I just purchased an adaptor for the vsmile learning system, so we didn't have to use batteries. I followed instructions on how to plug it in correctly, but when I plugged the ac adaptor to the vsmile, it...
You have to take out the Batteries.
also, the connector on this adaptor is incorrect for some Vsmile consoles. (most that are about 5 years old now).
Make sure you are using the right plug, and it is inserted fully into the console with no batteries. Then, it should work.
Jan 24, 2010 | Vtech V.Smile Adapter
I cant get the bloody controller working, and just have an anoying, little thing come on, repeating vsmile, drives me nuts, what am i doin wrong? brand new system!!!! helllp me!!!
Make sure the controller doesn't need batteries, and make sure it's plugged into the proper input on the vsmile system. If it's permanently attached to the vsmile system via a wire, then you may have a defective controller/vsmile and you should take it back and exchange it for another one.
I hope this helps :)
Best Regards,
James
Jul 21, 2009 | Toys
Goodman gmp050-03 heater
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Dec 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Vsmile game unit
Try cleaning the contacts on the games. Push back the sleeve on the game and clean good with alcohol. If this doesn't do it, unplug it, and clean the contacts inside the unit with a qtip.
Hope this helps!
Nov 30, 2008 | Vtech V.Smile TV Learning System
Vsmile will not turn on
HI! Have a few ideas for you. First, are the batteries brand new never used good batteries? Also, are you sure they are in the correct way? If so, try to reset the system. Unplug all cords from the Vsmile. Then, for a full timed minute, press down BOTH buttons on the front of the console. After the minute, plug everything back in and try to power it up. If this does not work for you, please contact Vtech Customer support. You can reach them at 18005212010. Hope you find this helpful! Good luck! :)
Sep 08, 2008 | Vtech V.Smile Pocket
Vsmile home unit and 2 Vsmile pockets no longer work! GR!!!
You should definately call customer service! I had to do this with our vsmile and they were very helpful with tech issues immediately. You can call them at 1.800.521.2010. One thing to try, they had me do this on the home unit. Unplug everything, then hold down both buttons on the front for one full timed minute. This resets the unit. See if this works for you. They will ask you to do it on the phone first anyway. If not, I hope they are able to suggest other helpful solutions for you! If not, you can find a good deal on a new one on ebay. Good luck! I know how much the kids enjoy this unit!! :)
Aug 13, 2008 | Vtech V.Smile TV Learning System
I was given a nice sony handycam camcorder. i was told the battery is probley dead
Batteries have a limited life even if they are constantly charged.
Leaving batteries in constant charge will limit their life by causing gas leakage. Once depleted, they must be replaced. There is also a small button battery that keeps unit memory up, if you do not use camera for months at a time, replace this battery also.
Ni-Cad batteries need to be refreshed ony once a month by discharging them fully, then recharging them fully for best performance to erase memory effect
May 01, 2008 | Sony Handycam CCD-TRV37 Camcorder
Vtech V.Smile Pocket Logo
1,560 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
