Question about Sony CDP-CX235 200-Disc CD Changer
CD player does not rotate
I have a Sony 200 CD player...The machine sounds like it is trying to load, but the carousel does not rotate...manually or automatically. I have checked and cannot find a CD that might be causing it to stick
Thanks
Hi there.
There could be a couple of reasons. I doubt very much that it is due to the lens. First thought is that it is probably the locking mechanism. If you look at the cd loading mechanism, there is a small plate with a locking tab that moves into place to hold the carousel still when the unit is loading a cd. This plate slides along the bottom of the unit between the cd loader and the carousel.
Secondly, it could be that the carousel is jammed on the rotating platter that it moves on. A couple of screws and it should come out - be carefull not to bend anything!
Thirdly, check the stepper motor that turns it - but I doubt this is the problem either as you said you couldn't turn it by hand either. You will need to remove the carousel to do this.
Good Luck !
Posted on Mar 07, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem is the lens.
u have to replace the lens.once you replace
the lens it will rotate automatically and will
start working.
try this out..
thank u..
rate me..
Posted on Feb 10, 2009
I have a sony 400 cd player and the lights come on, but the carousel won't move. When I press any button the button will light up but nothing happens. The blue light flashes all the time. Also, the door...
sounds like your loading mechanism is jammed up. I would take the cover off, and look in the back where the cd's load to play and see if you can see anything out of place.
Dec 04, 2013 | Sony CDP-CX400 400-Disc CD Changer
Have Sony cdp-c535 cd player. The door won't stay in. Keeps cycling in and out.
I had the same problem with our 5-CD Sony carousel player CDP-C535 (manufactured Nov 1993). I removed the top metal cover, and loaded five audio CDs into the carousel. After I closed the table, I pressed the carousel tight so that it stayed close, and hit the play button. The CD player tried to push the carousel out with quite a force. I needed to warp me fingers around the front panel to keep the carousel closed. After a few cycles of forcing the carousel to remain close, and caused two separate strong "clucks" from the gear area, the CD carousel became operational again. The diagnosis of gear problem seems right.
Nov 28, 2009 | Sony Audio Players & Recorders
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
A cd has gotten stuck in my Sony 5 cd/dvd carousel player. Appears that the label on the CD had gotten soft (sticky) and when the carousel rotates it stays stuck underneth the top while the carousel moves...
As long as the cd hasn't caused any other damage to the electronics or mechanics of the player, it should be an easy fix. First, open your carousel then unplug the player to avoid shock. Remove the top lid of the player via the screws on the exterior holding it in place. From there, the stuck CD should be right there for you to reach in and remove. Hope this helps!
Mar 24, 2009 | Sony CDP-CE375 5-Disc CD Changer
Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Jan 22, 2009 | Sony CDP-CX235 200-Disc CD Changer
Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
Dec 27, 2008 | Sony CDP-CX53 51-Disc CD Changer
Sony CDP-CX300 CD won't play
The rubber drive belt for the c/d load mech is streched or broken,
replace the belts there is another that drives something else so change them both while you have it open
Sep 17, 2008 | Sony CDP-CX300 CD Player
CD won't play; continually shuffles from one CD to another
did it just start doing this....how long have you had the unit for?
Dec 16, 2007 | Kenwood CD-223M 200-Disc CD Changer
Sony CDP-CX235 200-Disc CD Changer Logo
391 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
