Question about Palm Treo 500 Centro
Micro sdhc card
Where do i access the memory card from menu,,??in what application does it appear,,?
Ok,, I refered to e-handbook( instruction manual ) and the problem was explained,,
1. open the application containing the file you want to save,
2. press menu right soft key and select the option you want to save ,
3. press menu... select option for where you want to save info,,,, and select STORAGE CARD,,,,
4. press save ,,,,,,,,,,,,,,,Bingo its done,,,,,,
Hope this info is of use to others,,, Herb,,,,,
Posted on Feb 12, 2009
Why isn't my computer reading my micro sdhc card in a sdhc adapter, yet when i plug in a 'normal' sdhc card' it appears in my computer
The PC should be able to see 32GB.
Before the adapter, the first thing to check is the driver for the card reader.
The next most likely: the adapter is bad.
This is also a common problem
Jul 28, 2015 | PNY 32GB MicroSDHC Class 4 Memory Card...
Tip
How to unlock /removed password in your memory card
hi,
most of the time we are putting a password in our memory card so that the others cannot view the important and sometimes the confidential files..but unfortunately we forget it so what we are going to do if we cannot open our memory card?if we are going to a cellphone shop we are spending much money ,if we buy a new one we also spend ...
i want to share how to unlock/ removed password in your memory card micro sd...this is applicable only for the card like MINI SD(this is bigger than micro sd and used in nokia phone like n73 ,n80 ) and for MICRO SD (used in nokia E-series ,classic nokia like 3500c ,6300 ,3110c ,7210c etc and other chinaphone )...
tools you need is high end phone like nokia 5800 ,n95 ,e63 ,e71 etc...(for phone using mini sd like n73
you need an adaptor..
here is how..
1. insert your micro sd at nokia 5800 , memory card password will appear just cancel it..
2. go to menu,applications then file manager then you will see that memory card is locked..
3.open memory card you will see memory card locked
4. press options >memory card options and format memory card will appear
5. wait until formatting is finished
6.you will now rename the memory card and the password is gone...
note: in this process all your data will be lost but but you have no choice because no other way to
removed your password than this...
i hope it will help you ,thanks for trusting fixya
on Feb 09, 2011 | Cell Phones
How to unlock the micro sd memory card's password
Sorry. You can't. But you can usually recover use of the card by inserting it into an external SDHC card reader (using a suitable micro SDHC to SDHC adapter) and then refomatting the card. You may need to use the host computer to go into the cards properties first to uncheck the "read only" status.
This makes all data stored on the card overwriteable as if it's no longer there, but there is plenty of free/cheap data recovery software which can recover data from reformatted memory cards as long as the card has not been used after formatting.
Jul 17, 2011 | Skque 16GB MicroSDHC / MicroSD / Micro SD...
BlackBerry 8310 when i open.could not start the camera.Close other applications and try opening the camera again. plz tell me soon whats i m doing
It's basically a memory issue. You need so much available memory for the phone to operate, to run the camera and to store the pictues. Have you changed anything about the phone between the time it worked and when it stopped working? How many emails and txt messagess have you stored on the phone? Check the phone status (menu, options, status) for free memory... recommendation is a minimum of 8-10 MB. I'd also suggest getting a memory card (transflash/micro SDHC).
Check out Blackberryforums.com... there is an excellent sticky in the main section about freeing up memory - removing applications and features that you do not need/want/use to free up memory. Typically, I have about 28MB free plus a 4GB SDHC memory card.
close all apps out also
Dec 05, 2010 | RIM BlackBerry Curve 8310 Smartphone
UNABLE TO ACCESSMY 4GB MICRO SD CARD
Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
MEMORY FULL MESSAGE WITH NEW MICRO SDHC MEMORY CARD
Your camera may be telling you that the internal memory is full. With the card out of the camera, go into the menu and find "format" to erase the internal memory.
May 04, 2010 | Samsung NV3 Digital Camera
How do you format a Sandisk 4GB micro sdhc card so it can be used in a nokia 3109C?
Place the card into your phone...
To format a memory card, select Menu > Gallery or Applications, the memory card folder , and Options > Format mem. card > Yes.
When formatting is complete, enter a name for the memory card.
Nov 15, 2009 | SanDisk 2GB microSD Memory Card
Cannot install 4GB card into TL220. Do I have the
According to Samsung's page on this camera, the following memory can be used:
External Memory(Optional) : Micro SD (up to 4GB)
Micro SDHC (up to 8GB)
4 GB is acceptable, but I think you do not have the correct type of card. You should be using a Micro SD or "Micro Secure Digital" (up to 4GB capacity) or a Micro SDHC or "Micro Secure Digital High Capacity" (up to 8 GB capacity) card. This is very different from an SD or SDHC card. These Micro cards are very small (smaller than your thumbnail) and are often packaged with an SD adapter card. Regardless if sold with or with out the adapter, the package should say Micro SD or Micro SDHC on it somewhere.
Oct 02, 2009 | Samsung Cameras
I dont know how to use my sandisk to transfer from my cell phone to computer. which chip goes into the comp. usb port. the adapter or the transflash?
Some pc's have card reader slots which allow you to simply take the card out of one device and insert it into the card reader slot on the pc.
After this is done, the memory card becomes accessible.
My cell phone has a Micro SDHC card slot but my pc does not. In order to access the M-SDHC card from my pc I have to insert the card into the USB adapter that was provided with the Micro-SDHC card when I purchased it.
After the card has been inserted into the USB adapter, I then plug the USB adapter into an open USB slot on my pc which gives me access to the files on the Micro-SDHC card.
Sep 11, 2009 | Dell Computers & Internet
Palm Treo 500 Centro Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
